Author Topic: Wheel brush  (Read 3561 times)
Offline crashdesk
  • -Given: 36
Wheel brush
« on: October 14, 2011, 09:37:36 pm »
I'm looking to get a wheel brush and seen this one used by Paul Dalton. Anyone know the long one for the insides. Best one I have seen as any others I have looked at have wire in the middle and sticking out at the end which seems totally and utterly stupid as you 'may' scrath the laquer.
&feature=relmfu
What do you use?
Thanks,
C
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
Re: Wheel brush
« Reply #1 on: October 14, 2011, 09:51:39 pm »
Offline RussZS
  • -Given: 88
Re: Wheel brush
« Reply #2 on: October 14, 2011, 10:00:43 pm »
Hes using wheel woolies which you can get from Polished Bliss (£36).  I'm not a fan myself.  I use the EZ Detail Brush
The other brush is a Swissvax Wheel Brush, also available from PB
Offline crashdesk
  • -Given: 36
Re: Wheel brush
« Reply #3 on: October 14, 2011, 10:15:53 pm »
@stephenED30 That brush be good for Monza 2's? See you are an Ed30 with I presume pescaras. Got some Finnishkare so will be using that.
@russZS Will check out that Swissvax brush
Thanks guys
Offline keith
Re: Wheel brush
« Reply #4 on: October 19, 2011, 10:14:27 pm »
That Vikan brush has very strong brissles so be carefull on powder coated/sprayed wheels as you could mark them, EZ is good on motorbikes but your better of with the car version and stronger one - Daytona speedmaster.
Re: Wheel brush
« Reply #5 on: October 19, 2011, 10:36:13 pm »
I use an EZ brush on the alloy spokes, and a swissvax-style brush for the faces/edges.
Offline Eccie
  • -Receive: 25
Re: Wheel brush
« Reply #6 on: October 19, 2011, 11:21:36 pm »
I use an old brush from polished bliss (just checked and they don't appear to sell it anymore) is like a small bog brush, I just use it to clean the back of the wheels if they are particularly dirty.
Having said that, since sealing them with Werkstat prime and two coats of FK1000p it doesn't take much to clean them now; snow foam + power wash+ wash mitt & soap and they're all done
Mine are Monza so i can get the wash mitt and my little hands to the back quite easy :P
Offline SimonBash
  • -Given: 22
Re: Wheel brush
« Reply #7 on: October 20, 2011, 07:54:02 am »
Another vote for the EZ, excellent full stop, great on my Monza's.
I also use a Swissvax 'style' brush for the faces, Envy Valeting do a set of these brushes for less than SV one :happy2:
Agree with Russ wheel woolies are not worth the money IMO.
Sealant wise Auto Finesse Mint Rims or Gtechniq C5 best options IMO.
Re: Wheel brush
« Reply #8 on: October 20, 2011, 05:28:08 pm »
Same here, EZ detail brush for me!  :happy2:
IMO the mini version is much easier to use and more 'controlable' than the larger one!
Re: Wheel brush
« Reply #9 on: October 20, 2011, 05:45:16 pm »
I use the mini version for the front grilles! Perfect size to get in between the honeycombed areas.
Offline SimonBash
  • -Given: 22
Re: Wheel brush
« Reply #10 on: October 20, 2011, 05:56:35 pm »
The big one does cause a bit of splashback, however it is better at cleaning the rear of the spokes etc.
I also have the mini one though :wink:
Re: Wheel brush
« Reply #11 on: October 20, 2011, 06:06:31 pm »
I tend not to bother cleaning the backs unless the wheel is off the car. A bit difficult otherwise. Large one is great for the pescaras. For monzas, a wash mitt is more than enough.
Offline SimonBash
  • -Given: 22
Re: Wheel brush
« Reply #12 on: October 20, 2011, 06:09:42 pm »
Good point on the mitt for Monza's, old wash mitt is ideal :smiley:
Large one always comes in handy when doing other peoples cars for me :grin:
Re: Wheel brush
« Reply #13 on: October 20, 2011, 06:14:04 pm »
I still need to figure out how to do the areas when there's barely any room between the tyre and the arch. Fronts aren't too bad as you can move the steering wheel but the rears are very difficult. This is despite me having an underbody lance.
Offline SimonBash
  • -Given: 22
Re: Wheel brush
« Reply #14 on: October 20, 2011, 06:17:23 pm »
Plush the cr*p carpet liners in the rears!
I give it a soaking with the PW then a load of megs super degreaser, then scrub with a long handled vikan brush so you can get right in there. The small EZ also works well.
Amazing how much mud etc comes away from the top inside of the arch :scared:
