Author Topic: Revision D Diverter Valve  (Read 7375 times)
Offline Vdub13799
« on: October 15, 2011, 01:58:49 pm »
Car is due a service in a 1000 miles and is standard, should I change this whilst everything else is getting done? Thanks
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=2gggtrbmufeieqv3oei415t4fm&/topic,19740.0.html
Re: Revision D Diverter Valve
« Reply #1 on: October 15, 2011, 02:13:08 pm »
I changed mine and noticed no difference in performance. I would leave it if it's working ok.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #2 on: October 15, 2011, 02:24:47 pm »
Yeah dont change if it's working fine... Only change if loss of boost or remapping...
Dom
Diesel Daily Hack.
Offline vRS_Pagey
  • -Receive: 59
« Reply #3 on: October 15, 2011, 06:24:45 pm »
As above, I only upgraded due to my original have a split diaphragm.  Also if you have an ed30 the dv is at the front if the engine so a 5 minute job to swap.
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #4 on: October 15, 2011, 08:49:58 pm »
Done mine the other day, only took half hour. Had a rip in it and it was a rev c on it so as its 05 plate I think its not the 1st time its been replaced
Offline Vdub13799
« Reply #5 on: October 16, 2011, 01:38:25 pm »
Mines a 06 gti, feels quick enough but because your here about them a lot just wondered if its actually as quick as it should be?? Thanks everyone
Offline Jungle_Faced_Jake
« Reply #6 on: October 16, 2011, 02:07:15 pm »
I'd replace it as a matter of precaution if you're going to get a remap, otherwise if you are on the stock map and it appears to be running OK just leave it.
« Last Edit: October 17, 2011, 06:59:54 pm by Jungle_Faced_Jake »
Offline robby
« Reply #7 on: October 16, 2011, 05:19:41 pm »
Is it the same part number for the ED30 and standard GTi D/V?
I don't suppose you know of any fitting guides to change them over on an ED30?
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #8 on: October 16, 2011, 05:56:20 pm »
I believe its now a standard part on this engine, part number is 06H 145 710 D
With the ED30 i think its just a case of removing the engine cover then undoing 3 bolts to remove
Offline robby
« Reply #9 on: October 16, 2011, 06:24:21 pm »
Thanks, another little "mod" to add
Offline Phil1980
« Reply #10 on: October 16, 2011, 10:18:43 pm »
I would leave it only replace it if its broken. :smiley:
BLACK, 3DR, GTI, XENONS, MONZA II's.
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #11 on: October 16, 2011, 10:36:28 pm »
Not a bad call that, thought mine was the cause of my hesitation/ stutter so bought the D revision (£53 later) and after getting the old old version out it looked fine...plus a bit of a pain to get to on normal gti as you probably have read.
Offline robby
« Reply #12 on: October 17, 2011, 05:35:10 pm »
[/quote
Could sell me your then  :wink:]
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #13 on: October 17, 2011, 05:47:24 pm »
[/quote
[/quote]
 :smiley: you are welcome to the old one on the cheap of you like, still in the garage
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #14 on: October 17, 2011, 06:46:54 pm »
Is VW likely to be the cheapest place to buy one? I noticed Awesome are selling them for £52.79...
