Author Topic: Another offset question  (Read 1333 times)
Offline Syrag64
« on: October 15, 2011, 02:19:23 pm »
Been offered some 8 x 18 et 35 and 9 x 18 et 40, would these go on without too much trouble or do I need to mod the bodywork?  Car will be lowered on collies.
Also what size tyres should I get?
  :drinking:
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
Offline vRS_Pagey
  • -Receive: 59
Re: Another offset question
« Reply #1 on: October 15, 2011, 05:32:55 pm »
Ok, the 8J's will stick out a further 22mm and the 9J's and extra 30mm.... :surprised:
They will go on, but if you run the coilovers to low I would say they would definitely foul the arches particular the 9J's.  Tyre wise, 225 will sit fine on the 8's, but I would step up to 235 on the 9's with a 35 profile possibly.
The above measurements are compared to standard 18" Monza's by the way (7.5J ET51).
For future reference you could use this offset calculator, its the one I use.  :happy2:
http://www.1010tires.com/WheelOffsetCalculator.asp
« Last Edit: October 22, 2011, 06:59:14 pm by vRS_Pagey »
Offline dub singh
  • Snakebite Chasers...
« Reply #2 on: October 18, 2011, 11:12:40 pm »
Ran a similar offset before...
had
205/40's on the 8J fronts
215/40's on the 9J rears
-2 Camber on the rears because mine were ET35 Rears...
and dropped 50mm on coillies
If you're having Audio problems i feel bad for ya son... I've got 99 problems but Bass aint one!
