Author Topic: Avro Vulcan XH558 - Last flight of 2011 / First flight of 2012  (Read 15192 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=i9bnlbqtq8f7t1k3gj8kdelmqo&/topic,19740.0.html
Re: Avro Vulcan XH558 - Last flight of 2011 / First flight of 2012
« Reply #75 on: May 30, 2012, 02:46:51 pm »
Ohh ok. When I was there they definitely had one engine out im sure of it.
« Reply #76 on: May 30, 2012, 03:17:06 pm »
They may well have and put it back Rich but it was still running on last years engines at the start of this year.
« Reply #77 on: May 30, 2012, 03:24:53 pm »
« Reply #78 on: May 30, 2012, 05:04:39 pm »
Fresh from the horses mouth.
Quote
Engine Damage Update - issued Wednesday 30th May - 5pm
The technical team spent yesterday (Tuesday) investigating the engine damage on XH558, to determine its cause and to start assessing the timescale and cost of rectification.
We have already established that both engines No.1 and No.2 on the port side are sadly beyond repair, both having suffered blade damage and the effect of excessive heat.
The primary cause of the damage has been determined to be ingestion of silica gel desiccant bags. The most likely sequence of events was that material was ingested by No.1 engine, which surged and suffered LP compressor blade failure. Debris was then sucked into No. 2 which then also failed.
All relevant agencies and technical authorities have been informed. “We have been greatly reassured by the support from industry colleagues, and would like to thank all those who have offered help,” said engineering director Andrew Edmondson.
We would also like to place on record our thanks to all at Robin Hood Airport Doncaster Sheffield for their swift and professional reaction on Monday, whilst also apologising to those affected by delays or diversions.
In accordance with normal procedures, a formal investigation into the incident has been opened, chaired by the Chairman of the Trust’s Safety Review Committee.
The technical inspection has so far showed that no airframe damage was sustained, with damage being limited to the engines. The next step is to replace the damaged engines with two from the Trust’s remaining stock. Timescales for a return to flight are not yet clear – we will of course update the web site with progress and give details in the e-newsletters each week.
“We are deeply sorry that this incident has happened, and at this time in 2012. The additional unplanned costs are clearly very worrying as resources are, as ever very tight” said the charity’s chief executive, Dr. Robert Pleming. “We are actively working on a plan to recover our Jubilee season schedule and we will share this with you as soon as practical via the newsletter, Facebook page, Twitter feed and the web site.”
With many thanks to all for continuing to support Vulcan XH558.
The Vulcan Team
http://www.vulcantothesky.org/phpBB3/viewtopic.php?f=2&t=4155
Looks hopeful but as said unnecessary expense right at the start of the display season.
