Author Topic: 2.0TFSI Oil Pick up pipe blocked = Low oil pressure warning  (Read 46647 times)
Offline Kaza
    • Facebook.
Re: 2.0TFSI Oil Pick up pipe blocked = Low oil pressure warning
« Reply #30 on: December 06, 2012, 09:19:13 pm »
Not sure if it ever has been. However we cleaned it all out but it's still flashing, but only when the car is up to temperature and when I have been driving for 20 minutes or more.
Offline zerolag
  • Ass of Ennis
« Reply #31 on: December 06, 2012, 09:31:12 pm »
What does VCDS say?
Has it damaged the Oil pump?
Offline Kaza
    • Facebook.
« Reply #32 on: December 06, 2012, 09:55:16 pm »
I can't see the pump itself being damaged. Surely if that was the case I would see the warning continuously? Or the car wouldn't feel too great?
I haven't had it checked via vag com, but one of the first times it happened a friend ran a check and no fault codes came up, or anything to do with oil or the pump etc for that matter.
Munchie
« Reply #33 on: December 24, 2012, 03:43:49 pm »
Hi guys. Thought I would post this for your information.
Pulled away from a junction today and oil warning went off for
3 seconds then the engine cut out. I did try to start the engine again
but it does not start. Read the DTCs but nothing there. Going to get through
Christmas and drop the sump. Will keep you informed.
Offline Kaza
    • Facebook.
« Reply #34 on: December 25, 2012, 07:38:19 pm »
Oh dear that doesn't sound good :-/ if it has cut off I can only imagine it is a slightly more serious problem than what I had. Which just turned out to be the switch being dodgy so I just got that replaced.
Munchie
« Reply #35 on: January 02, 2013, 03:33:29 pm »
I've had a chance to drop the sump and its very clean. No blockage or sludge.
Managed to trace problem to a poor connection at the clocks. Took 20 mins to find and fix the clock
Issue. Wish I had checked that first. Anyway at least I know oil pick up is good.
Offline Chris08pirelli
« Reply #36 on: June 08, 2014, 06:43:26 pm »
This has just happend to my pirelli edition what a fright i got thought i had blew it up lol this has helped alot cheers guys!
Offline shoaybmakda
  • -Receive: 54
« Reply #37 on: July 28, 2017, 12:21:07 pm »
Anyone got a new link with working images?
Would like to have a go at this. Damn you photobucket!
Offline RobC
  • -Receive: 20
« Reply #38 on: July 28, 2017, 12:30:03 pm »
I put a post up about this yesterday in the Photobucket thread, hopefully this will help...
Chaps,
I dont know if this works for everyone but Ive found a workaround that works for me. Its not neat, but it works and will be useful for some of the 'How To' guides at least...
(Im using Google Chrome if that makes a difference)
- Right click the photo and click 'Open in New Tab' (When it opens in a new tab it will still show the Photobucket ransom message)
- Hold Ctrl & press F5 to refresh the page and once it refreshes you should be able to see said image
- Said image should even now show up in the post you were viewing originally (may have to refresh it)
Let me know if it works for you :happy2:
Offline shoaybmakda
  • -Receive: 54
« Reply #39 on: July 28, 2017, 12:39:48 pm »
Thanks for that @RobC
Just need a work around for mobile devices now!
