Author Topic: Help with headlight washer retrofit on TDI  (Read 9188 times)
Offline parks
  • Red ED30 No. 1778 Detailing World member
Re: Help with headlight washer retrofit on TDI
« Reply #15 on: November 03, 2011, 03:43:56 pm »
what was the cost from the dealers for everything?
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline skard
  • -Receive: 245
« Reply #16 on: November 03, 2011, 03:55:45 pm »
I'm not quite sure as I binned the receipts and got other parts at the same time.
Buying everything new from a dealer you're looking at about £200. The Kufatec wiring loom is pretty expensive.
I already had mouldings sprayed nup, and got the jets/pump on ebay.
If you can get the jets/mouldings/pump cheap, then you can drill your current bottle and just need ~2m of hose with some clips and do it for a lot less (plus the loom).
Offline mortygttdi
  • -Receive: 146
« Reply #17 on: November 03, 2011, 09:30:31 pm »
Now get some xenons on :happy2: and you can tackle the auto level retrofit :P
Darren
Offline skard
  • -Receive: 245
« Reply #18 on: November 03, 2011, 10:09:37 pm »
Utterly tempting but still in two minds whether to keep the car medium-long term.
Can't justify £700+ on lights for a car that's dropping in value quite a bit  :scared:
Offline Moz
« Reply #19 on: May 09, 2012, 09:04:30 pm »
Sorry for dragging this up, but I think I'm going to give up based on your thread.
Buying all the Xenons and looms was bad enough now all this washer stuff is driving me mental.
I might try sell my stuff and try get my money back from Kufatec and call it quits!
Offline skard
  • -Receive: 245
« Reply #20 on: May 10, 2012, 07:06:04 pm »
Nah it's actually very straight forward in hindsight, if you get the list of parts needed you can't go wrong.
Issues I had were due to the way the cables were routed (must've been an early setup) as I changed it with new hose/couplings and routed it the obvious way and thus no leaks.
Give it a bash  :happy2:
