Author Topic: Intercooler hose seal part no required.  (Read 9192 times)
Re: Intercooler hose seal part no required.
« Reply #15 on: October 24, 2011, 11:21:44 pm »
Bugger.  So I wonder if i would be stuffed the the turbo discharge & intercooler pipe too?
The hoses taper to fit into the standard turbo discharge & throttle body pipe on a standard car so it should work with the "uprated" pipes as well.
Sorry to be a PITA but you confused me there  :ashamed:
« Reply #16 on: October 24, 2011, 11:30:22 pm »
Although the outlet pipes on the APR IC is larger than standard and needs the bespoke hoses, at the other end of each of the 2 hoses the couplers mates up to the standard turbo discharge & throttle body pipes.
The "uprated"  turbo discharge & throttle body pipes should have the same coupler size as standard so they should work with the APR IC hoses.
Hope that makes it clearer.
« Reply #17 on: October 24, 2011, 11:32:52 pm »
Okidoke, that is clearer to me Thanks  :happy2:
Want a Braille battery for your discharge hose?  :wink:  If not I will have to sell it and pay you as Ive wanted it for a while just put off by the need for machining, dont want it being inferior to original design
« Reply #18 on: October 24, 2011, 11:37:20 pm »
Let me think, perhaps not but nice try...   :smiley:
