Author Topic: Running a decat  (Read 4334 times)
Offline Weston
Re: Running a decat
« Reply #15 on: March 07, 2012, 10:41:39 am »
Whats the difference between a large bore downpipe and decat?
A large bore down pipe will be wider than standard, 3" v. 2.75" I believe. A decat means the cat material from within the DP has been removed so essentially it's just an empty pipe. Both allow greater flow through the exhaust.
GTI going...
Offline pd9264
Re: Running a decat
« Reply #16 on: March 18, 2012, 05:56:43 pm »
i put a decat on my gti and my eml hasnt come on, iv done about 500 miles. also iv got an extension piece on my second lamda sensor. its got a little hole in the bottom where it enters the exhaust. it stops the sensor picking up too much exhaust gas so it doesnt relise its got a decat. its only a cheap toyosport decat though.
Offline nezquick
Re: Running a decat
« Reply #17 on: March 19, 2012, 02:56:49 pm »
Just a quick question, I have a decat downpipe (3") mated to a resonated milly, the check light came on but cleared with vagcom - I am expecting it to come back within the 100 miles again. Is this potentially a MOT failure recipe? I love the sound of mine, really nice and quite when you want it to be and then when you give it some boot it sounds   :drool:
Offline Tamiyoman
  • -Receive: 39
Re: Running a decat
« Reply #18 on: March 21, 2012, 03:16:44 pm »
No CAT= MOT FAIL, light on or otherwise  :happy2:
Offline nezquick
Re: Running a decat
« Reply #19 on: March 21, 2012, 03:27:21 pm »
 :happy2: thought as much, thats alright I have a friend in the business so im sure he can help  :innocent:
Offline Tamiyoman
  • -Receive: 39
Re: Running a decat
« Reply #20 on: March 21, 2012, 03:39:40 pm »
Like most folks on here just stick it back on for the day, get MOT done then take off afterwards, only trouble is you will face fines etc if pulled over by the Highway Wombles (They operate regularly on A17).
Offline nezquick
Re: Running a decat
« Reply #21 on: March 21, 2012, 04:02:23 pm »
Yeah I think Ill do that although he passed me last time with a previous car that maybe shouldn't of passed. hmm, my car is quite enough not to draw attention to it if im gentle on the pedal so hopefully shouldn't have much of a problem thats why im tempted to just weld in a highflow sports cat but christ they're expensive
Offline Tamiyoman
  • -Receive: 39
Re: Running a decat
« Reply #22 on: March 21, 2012, 04:10:59 pm »
I have been pulled over by the highway wombles 5 times in 6 years always on A17 (At least they are not shutting the road!!), when you pull in its usually wagons, Vans, HGV's (Checking weights, dipping tanks etc as lots of Pikeys round Cambridgeshire/Lincolnshire using red diseasal) and Sports cars (clearly looking for Cat removals, tyres etc), had the pipe up my cars exhaust every time, they actually tried to stop me another time and started waving me in, just drove past them as I was in a bit of a hurry and no time for them messing about!!
« Last Edit: March 21, 2012, 05:17:41 pm by Tamiyoman »
