Author Topic: New Polar update FIS+ FIS Advanced 0.1.9  (Read 2921 times)
Offline Richn83
  • -Given: 49
  • -Receive: 85
« on: October 26, 2011, 08:43:19 pm »
New update for all polar users below is off their website.
Hi to all Auto-Polar community
This is our last update for FIS+ customers
  Firmware FIS+ v0.1.9
  • Improved diagnostics functions :
Detected problem when we try to codify units with vehicle in movement, ECUs not allow acces via diagnostic on
movement, so we restrict access in this case.
Improved menu navigation when you enter to see any value, now not exists delay time after not configure any value
  • Improved mirror functions :
Added new screen when you configure position of mirrors (help screen)
Modified totally routines of movement for restrict movement in case that mirrors not be in correct position (blend)
Improved OFFSET function, for make a more precise configuration. Values from -9 to 9  (0 is normal value)
  • Other fixments and improvements :
Improved communication that solves problem with screen (after power on vehicle not appears)
Modified the screen of the parameters selection, now only will appear parameters supported by your vehicle
Other minor bugs and fixments (internal)
Any enquire, sugerence or question, please not doubt in contact with our staff at www.auto-polar.com/forum
Thanks in advance for all your attention,
with best regards,
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: New Polar update FIS+ FIS Advanced 0.1.9
« Reply #1 on: October 26, 2011, 08:52:38 pm »
Last or latest update Rich?  :wink:
Over the top mod list ;o)
Offline TonyZed
« Reply #2 on: October 27, 2011, 09:49:15 pm »
I updated mine today but haven't had time to play. :grin:
I did have a quick go with the dipping mirror option, but still can't get it to work. :ashamed:
TonyZ
Offline golfman
  • -Given: 17
« Reply #3 on: October 27, 2011, 10:12:25 pm »
TonyZ
Tony do you have a memory mirror on the passenger side?
scott :happy2:
Vag-com Hex+Can in scotland
I Hate Timewasters...
« Reply #4 on: October 28, 2011, 01:19:54 am »
Quick question, would the Polar FIS work on a Polo GTI MFD ?
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #5 on: October 28, 2011, 10:36:42 am »
They are working on white MFD's at the moment Hurdy not sure if the polo screen uses BAP or if its like the RED DIS systems but if it works in the same way as MK6 then it might work once they sort out there display layout.  For the moment I dont think it will  :sad1:
The latest Jake the next one will have some exciting things that you asked for awhile ago (a raft of new parameters EGT for one)  :wink:
Tony, try putting your mirror adjust switch on the R setting I can only get it to work when in that mode (but I havent changed to the new software) it also on the old software used to reset every ignition cycle  :stupid:  I need to check the new one and then speak to Ishmael about changing the coding.
Offline Kregiel
  • -Given: 28
  • -Receive: 20
  • Supersonic
« Reply #6 on: December 08, 2011, 04:05:41 pm »
Richn,
DO you have any Polad Advanced + for sale at the moment?
Paul
Offline kalu
« Reply #7 on: April 12, 2012, 09:20:30 pm »
Just updated to v0.2.4 and its the best update yet!
Features Bluetooth Emulation function that allows red LED highline display to fully function with bluetooth units which before only worked with white LED highline. Only beta version but works perfect for me :)
Full info is here:
http://www.auto-polar.com/index-showReg-38-load-module_news.php.htm
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #8 on: April 13, 2012, 08:57:27 am »
Interestign to hear Kalu, how are the rest of the functions?
Do you have parking sensors on your car?  if so have you tried the OPS emulation as someone was trying it last night at the meet and couldnt get it to function.
« Reply #9 on: April 13, 2012, 09:01:59 am »
Doesn't the emulation only work for skoda cars?
Offline kalu
« Reply #10 on: April 13, 2012, 05:43:35 pm »
OPS emulation only works with Skoda :(
However bluetooth emulation is working with VW. I have 974 highline with a 7P6 BT module and I can access phone menu in the clocks, view phone book, change settings etc... also the MFSW phone button works!
