Author Topic: Display cluster incorrect Air Temperature  (Read 1038 times)
Offline AdeMcG
« on: October 28, 2011, 08:13:35 pm »
Just been out in Chester (cheers Aled) and as I put the key in to the ignition, the temperature display read - 13 Deg C.
Strage, as it was cold, but around 10 Degrees.
On the drive home (motorway) it slowly ticked up until it read the correct temperature (9 degrees) but why the strange - 13 at start up?
Does it signify something wrong / on its way out? :confused:
Offline mortygttdi
  • -Receive: 146
Re: Display cluster incorrect Air Temperature
« Reply #1 on: October 28, 2011, 08:17:59 pm »
Yes mine used to do this its the outside temp sensor near the front bumper, take it out and clean it with WD40 or some other water penitration fluid :happy2:
Never had a problem since
Darren
  • -Receive: 291
« Reply #2 on: October 28, 2011, 08:57:28 pm »
Any ideas on where precisely the sensor is? Unless it's got a big arrow with flashing lights pointing at it, I'd probably miss it!
Offline mortygttdi
  • -Receive: 146
« Reply #3 on: October 28, 2011, 11:14:48 pm »
SW I believe its to the right of the lower center grill theres a bracket attached to the bumper carrier and it sits on that.
Darren
« Last Edit: October 28, 2011, 11:16:54 pm by mortygttdi »
Offline AdeMcG
« Reply #4 on: October 28, 2011, 11:49:58 pm »
Me too....unless a flashing red light with a sign saying " TEMP SENSOR" I would miss it too....I will have a look in the daylight tomorrow....thanks guys :happy2:
