December 23, 2024, 11:51:36 am
All Things Mk5
Technical Workshop
Air bag light on?
Topic: Air bag light on? (Read 1753 times)
Azzaroden
Taking part
-Given: 0
-Receive: 1
Air bag light on?
October 28, 2011, 10:09:22 pm »
I brought a golf mk5 1.6 se and the air bag light is on, the bloke said it came on after turning the airbags back on in the glovebox any ideas how to remove the light? Thanks
skard
Just look at my post count
-Given: 5
-Receive: 245
My Ride:
Re: Air bag light on?
Reply #1 on:
October 28, 2011, 10:13:32 pm »
Have it scanned with VCDS - it'll tell you the fault and let you attempt to clear it, although if it's a permenant fault it'll come back on.
Where do you live? There will likely be someone near you with a diagnostic cable.
danishmkvgti
-Given: 243
-Receive: 154
My Ride:
Reply #2 on:
October 29, 2011, 07:36:35 am »
when you locate the bad one, try to disconnect it, and clean the plugs as it's a common fault that the plugs gets faulty
Over the top mod list ;o)
Azzaroden
Taking part
-Given: 0
-Receive: 1
Reply #3 on:
October 30, 2011, 10:13:46 am »
Im in cannock west midlands? Would it be on
If the air bag was switched off at glovebox?
skard
-Given: 5
-Receive: 245
My Ride:
Reply #4 on:
October 30, 2011, 10:21:11 am »
Quote from: Azzaroden on October 30, 2011, 10:13:46 am
Well, yes it would.
Put your key in the airbag switch and turn it back on, if the light goes away then that's your source.
Azzaroden
Taking part
-Given: 0
-Receive: 1
Reply #5 on:
October 30, 2011, 11:05:25 pm »
Okkk mate ill try that tommrow cheers
Uncle Deedee
Just Arrived
-Given: 0
-Receive: 1
Reply #6 on:
November 01, 2011, 07:35:29 pm »
Its more than likely a connector under one of the front seats, you'll need it plugged in anyway to reset it.
Azzaroden
Taking part
-Given: 0
-Receive: 1
Reply #7 on:
November 03, 2011, 01:42:40 pm »
Iv turned airbag back on inside the glove box snd the light is still on
skard
-Given: 5
-Receive: 245
My Ride:
Reply #8 on:
November 03, 2011, 06:09:53 pm »
If you can't get your car scanned, try what others have written - trace your wiring and check the plugs.
Has it had a bump previously, deploying any airbags?
Azzaroden
Taking part
-Given: 0
-Receive: 1
Reply #9 on:
November 03, 2011, 06:40:31 pm »
Ill check the plugs mate & nope never had an accident mate
All Things Mk5
Technical Workshop
Air bag light on?
