Author Topic: Vredestein Sessanta pressure  (Read 1789 times)
Offline jordychris
« on: October 29, 2011, 04:13:15 pm »
I have just had 2 vreds fitted to the front on 18" monzas what pressure does everyone find best to run them at
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=pajmp7nob49unu54jto5nbsifg&/topic,19740.0.html
Re: Vredestein Sessanta pressure
« Reply #1 on: October 29, 2011, 04:15:28 pm »
Should be about 33-34PSI.
  • -Receive: 291
« Reply #2 on: October 29, 2011, 05:35:14 pm »
I thought Vreds were supposed to be higher pressure eg 41psi?
Offline jordychris
« Reply #3 on: October 29, 2011, 05:46:50 pm »
That is why i am confused
Offline winrya
« Reply #4 on: October 29, 2011, 06:02:04 pm »
No, I remember someone contacted vreds asking this question and their response was to run them as per vw spec.
I run mine around 2.3-2.4 bar. Vw recommend 2.2 but I've always found tyres wear far better at the marginally higher pressure.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #5 on: October 29, 2011, 06:03:04 pm »
..............on there ''official'' web site they do recomend high pressure?. I stick with the VW recomended pressure & they have handled/worn perfect. :happy2:
  • -Receive: 291
« Reply #6 on: October 29, 2011, 06:33:04 pm »
If it's at what VW recommend, surely its 2.6bar or 37psi?
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #7 on: October 29, 2011, 07:01:20 pm »
I run them higher, around 41PSI. Find they can be understeery otherwise.
« Reply #8 on: October 29, 2011, 07:27:07 pm »
41PSI sounds a lot. More likely to get understeer with more pressure in the front tyres.
Saint Steve
« Reply #9 on: October 29, 2011, 07:33:45 pm »
i was told by a Vredestein dealer to run 40 PSI and have done on both sets i have used up, and have experianced balanced tyre wear on all tyres with no handling issues.
« Reply #10 on: October 29, 2011, 08:04:03 pm »
How do they hold up under light to moderate braking Steve??? :popcornsoda:
  • -Given: 32
  • -Receive: 78
« Reply #11 on: October 29, 2011, 08:18:09 pm »
It's more of a vagueness on turn it. The grip very well so putting more air in them tends to give crisper turn in feel.
I'm on my third set now and I'm not sure they're a tyre I'll buy again. The PS3s I tried were definitely worth the additional cost.
