Author Topic: exhaust system warning  (Read 10833 times)
Offline peter215
Re: exhaust system warning
« Reply #15 on: November 04, 2011, 02:19:40 pm »
I Dont Know anybody local who can do it, local garage cant read the codes or something like that. The dealer never mentioned anything about half hour rates just that it would be £85 to diagnose fault
See if anyone on this thread is local to you and PM them.
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Ok thanks
MK5 Golf GTI DSG, 5 door 05 plate ,multi function wheel with paddles, leather interior,cruise control,parking sensors,armrest.
Offline robby
« Reply #16 on: November 04, 2011, 06:48:26 pm »
I'm driving an ED30
went into VW today for the fault codes reading - came up same as last time
They said it could be 1 of 2 things so will change the cheapest first, either charcoal canister (£137 fitted) or the valve (can't remember how much that was but they said it was a longer job so labour would be a lot more)
Booked in for next friday so we'll see what happens  :sad1:
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #17 on: November 04, 2011, 06:58:51 pm »
The valve is a £25 part and 30 minutes to fit.
I'm driving a black 5 door with Detroits if you see me around!
Offline robby
« Reply #18 on: November 04, 2011, 07:07:29 pm »
well the valve should have been cheaper than the canister then? bet they end up replacing that as well so i get charged for a canister which wasn't needed  :confused:
Mine's a red 3 door, usually driven on back of old ICI, Zeneca, or whatever it was called since (dalton green lane) and up Bradley road into Elland  :happy2:
  • -Given: 32
  • -Receive: 78
« Reply #19 on: November 04, 2011, 07:09:02 pm »
I work on Bradley Road :happy2:
Offline robby
« Reply #20 on: November 04, 2011, 07:26:38 pm »
I'll keep an eye out - 6.30am (ish) and 5.00pm (unless i'm working 2 hours o/t)  :happy2:
Offline tartanmartin85
« Reply #21 on: November 05, 2011, 03:04:21 pm »
I'm now a victim of the exhaust emission light and similarly have been doing much shorter journeys due to work. Car appears to be running completely fine, absolutely no change from normal.
I can't see anyone on the list but does anyone know about someone with VCDS in the Glasgow area? I'd really appreciate the help.
« Reply #22 on: November 05, 2011, 03:26:54 pm »
iirc rubber toe is from Glasgow and I'm guessing should have one.
Offline robby
« Reply #23 on: November 05, 2011, 03:32:28 pm »
Wonder if this problem is down to short trips - maybe by not running optimum temps for several miles it causes the problem?
« Reply #24 on: November 05, 2011, 03:59:13 pm »
Thanks for that, I've dropped him a PM.
Re. short distances, I've done a couple of 30 min runs on the motorway and a couple of blasts just to give it time to warm up. Can the light go off after a while? Is it safe to keep driving given that I notice absolutely no difference?
Offline robby
« Reply #25 on: November 05, 2011, 05:03:32 pm »
[/quote]
As long as the light is orange/ amber and NOT red then it is still safe to drive
I had my light reset the other week and it took 50 miles before it came back on - it wouldn't go out on its own :(
mine also feels no different to before
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #26 on: November 05, 2011, 05:41:58 pm »
The way that i got rid of it was to start the car, then turn it off and start it again. Do it about 3 times and the light goes out.
Had mine on VCDS today (many thanks to vwrascal - Dan, top guy :happy2:), and nothing popped up at all about the lambda sensor - which is what that light normally means, so wouldnt worry too much about it - unless red light as said above.
« Last Edit: November 05, 2011, 06:49:19 pm by brookesb32 »
Offline robby
« Reply #27 on: November 05, 2011, 05:46:00 pm »
The way that i got rid of the car was to start it, then turn it off and start it again. Do it about 3 times and the light goes out.
Didn't work on mine  :confused:
Offline PDT
  • -Receive: 142
« Reply #28 on: November 05, 2011, 06:02:01 pm »
Where in Northumberland are you?
« Reply #29 on: November 05, 2011, 06:12:27 pm »
Same for me so far, not sure if it might reset after the same period as the trip computer after a couple of hours?
