Author Topic: Offset  (Read 1172 times)
Offline Syrag64
Offset
« on: November 01, 2011, 04:35:52 pm »
I've searched but can't seem to find the answer  :ashamed:
What is the standard offset on a 17" monza?  is it 7.5"  or 7"?
I've seen some nice Merc wheels but can't use the offset calculator till I have the right size.
Will these fit?
http://www.ebay.co.uk/itm/280760755392?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Offset
« Reply #1 on: November 01, 2011, 04:44:29 pm »
what you're referring to is the wheel WIDTH
the offset is usually preceded by "ET" which is german for something - can't remember what. OEM wheels are 7.5" wide i believe
bolt pattern must be 5x112 (which Merc are i believe). can use the following offset calculator to figure out whether they fit or not:
http://www.1010tires.com/WheelOffsetCalculator.asp
from calculating from my OEM wheel these will stick out 22mm more. that's pushing it tbh. the wheels i'm after are further out by 15mm and i was led to believe they might rub
best of luck  :happy2:
« Last Edit: November 01, 2011, 04:46:15 pm by sub39h »
PLANS: Stage 2+
Offline Syrag64
Re: Offset
« Reply #2 on: November 01, 2011, 04:51:25 pm »
My bad yes i did indeed mean width :smiley:
