Author Topic: Changing spark plugs.....  (Read 1524 times)
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« on: November 01, 2011, 09:01:55 pm »
Going to do this at the weekend to hopefully fix the hesitation problem under acceleration
Borrowing the correct tools from a friend and competent with cars - my query is whether or not i need a torque wrench or whether you can just do them tight but not too tight?
If i do need one, anyone around bishops stortford / essex border have one i could borrow?  :smiley:
Offline damoegan
Re: Changing spark plugs.....
« Reply #1 on: November 01, 2011, 09:18:09 pm »
No real need to use a torque wrench, just nip them up tight  :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=l84p3dvm8cbdka4enfgksd7hck&/topic,19740.0.html
« Reply #2 on: November 01, 2011, 09:23:28 pm »
I'm sure there is a torque setting. Probably about 20ftlbs
Offline lee_
« Reply #3 on: November 01, 2011, 09:26:16 pm »
The torque setting is very low so most wrenches aren't capable, IIRC i ended up using a 1/4" drive torque wrench!
Tip of the day is to use two cable ties to pull the coil-packs!  :happy2:
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #4 on: November 01, 2011, 09:30:27 pm »
Yeah I saw that on a thread somewhere, legendary way of removing them.
So basically just give them a good tighten, (assume that is what nip means)
Offline damoegan
« Reply #5 on: November 01, 2011, 09:52:11 pm »
25-29lb/ft (35-40Nm)  :happy2:
« Reply #6 on: November 01, 2011, 09:54:02 pm »
Oooooo I wasn't far off. :-p
