Author Topic: Vacuum tap for boost gauge??  (Read 4094 times)
Offline Dan648v
  • -Given: 28
« on: November 01, 2011, 09:49:49 pm »
Had a search but I'm not getting the answers I'm after!
Recently bought a newsouth boost gauge in an oem air vent pod and looking to fit it but don't know where to plumb in my ECS t-piece (no buzzing) for my vac line?
Also where am I best powering it from to come on with my lights?
Any help lads is appreciated!! :happy2:
If it helps car is a 07 ed30 with auto lights
Offline Dan648v
  • -Given: 28
Re: Vacuum tap for boost gauge??
« Reply #2 on: November 01, 2011, 10:04:43 pm »
Cheers those Damien!
I understand the wiring now but still Not clear where I need to take my vacuum feed from in the engine bay?
Might have just been a long day but just can't see it
Offline damoegan
« Reply #3 on: November 01, 2011, 10:09:41 pm »
Either from the vac line onto the DV or from the main vac line going into the inlet mani (you can get a boost tap kit from the likes of Forge Motorsport)  :smiley:
Offline liver
« Reply #4 on: November 01, 2011, 10:16:55 pm »
mine
then i ran it into the cabin behind the battery, then under the dash all tidied away
earthed
Offline Dan648v
  • -Given: 28
« Reply #5 on: November 01, 2011, 10:19:57 pm »
Now thats perfect mate!! A pic speaks a thousand words!
Thanks for the help lads!!  :happy2:
Offline liver
« Reply #6 on: November 03, 2011, 01:32:27 pm »
how did you get on with the fitting?
Offline Dan648v
  • -Given: 28
« Reply #7 on: November 03, 2011, 01:38:59 pm »
Not attempted it yet, had the engine cover off yest looking for the vac pipe ( which I found) and then just having a look around to see where best to pass through the bulkhead.
But seems easy enough now, thanks for the pics!
I've got a ecs t-piece for the vacuum take off but have been offered a forge adaptor which goes on the main inlet vac take off and not sure which one to use?
« Reply #8 on: November 03, 2011, 05:21:06 pm »
I can attest that the Forge adapter is simple to fit and works well.
Offline Dan648v
  • -Given: 28
« Reply #9 on: November 03, 2011, 07:46:14 pm »
Yeah it looks to be an easy fit and a tidy install aswell! I have no use for the other blanks on it but boost. I'm tempted for it but I then have a ecs t-piece that's obsolete, oh well.
