Author Topic: Boot won't open  (Read 9587 times)
Offline golf nutter
  • -Given: 19
Boot won't open
« on: November 03, 2011, 04:56:45 pm »
went to shut the boot on MY08 3dr GTi but didnt shut it properly as indicated on the dash.  so i got out and pushed it shut gently and it seemed to shut...dash indicator went off.  got to the end of my journey, went to the boot...and it wont open.  tried locking, unlocking, all sorts and for some reason when i lift the boot release handle nothing happens.  any ideas guys please?
Re: Boot won't open
« Reply #1 on: November 03, 2011, 05:19:18 pm »
Had this happen in the past and it cured itself after a drive on a roughish road.
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
Re: Boot won't open
« Reply #2 on: November 03, 2011, 06:16:46 pm »
i had this on mine when i first got it , you have a little solenoid that clips into the handle. it was replaced and never had an issue again
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline golf nutter
  • -Given: 19
Re: Boot won't open
« Reply #3 on: November 03, 2011, 06:33:45 pm »
i will try the rough ride seeing as its free!
the solenoid...that can be bought on its own without having to get the whole handle?  you must have to get the boot open i guess to be able to replace that part?
any other suggestions?
Offline DamoP
  • -Receive: 115
Re: Boot won't open
« Reply #4 on: November 03, 2011, 06:37:17 pm »
Yes mate you get it separately . Take the boot trim off and you will see it sticking out of the handle mechanism
Offline brookesb32
  • -Given: 59
  • -Receive: 75
Re: Boot won't open
« Reply #5 on: November 03, 2011, 06:43:17 pm »
You probably already know this, but hey can't hurt mentioning anyway, not sure about the solenoid etc but you can open the boot from the inside by popping of the little plastic insert and flipping the level.
Other thought could be lose connection to the unit?
Offline golf nutter
  • -Given: 19
Re: Boot won't open
« Reply #6 on: November 03, 2011, 07:53:45 pm »
er...no...i didnt know this.  not sure what you are referring to...could you direct me to the bit you mean please?  thanks
Offline brookesb32
  • -Given: 59
  • -Receive: 75
Re: Boot won't open
« Reply #7 on: November 03, 2011, 08:03:35 pm »
Sure, if you fold down the rear seats and crawl into the boot you will see a small round plastic blanking type plate with the top of the circle cut off (so you can get a finger in to flip it off) it is in the middle of the boot hatch near to the bottom where the latch is has a pic of a car with boot up on it
Will pop out in a mo and take a pic if that would help?
« Last Edit: November 03, 2011, 08:37:48 pm by brookesb32 »
Offline golf nutter
  • -Given: 19
Re: Boot won't open
« Reply #8 on: November 04, 2011, 09:18:39 am »
Thanks for the photo...I recollect seeing that now. Cheers  :happy2:
