Author Topic: Changing turbo - low boost  (Read 15530 times)
Offline b21playa
« on: November 05, 2011, 06:46:17 am »
My car isn't making as much boost as it should, so looking at what this
could be caused by
I've got a revision d diverted valve, new pcv. I will check all inter cooler hoses etc. foam air filter needs a clean
If it is the turbo, is it hard to remove? Any guides about?
Offline edd666999
  • -Receive: 89
Re: Changing turbo - low boost
« Reply #1 on: November 05, 2011, 07:06:28 am »
mapped? who's map?
any other mods?
Any logs to show us?
When doesn't it make boost in the rev range?
Offline b21playa
« Reply #2 on: November 05, 2011, 06:00:25 pm »
mapped? who's map?
any other mods?
Yes mapped with bluefin. Mods include carbonio intake, forge twintercooler, miltek sports cat, and tbe.
Was logged by jody at midlandvw. Will post logs of actual/specified vs rpm
Offline edd666999
  • -Receive: 89
« Reply #3 on: November 05, 2011, 06:35:30 pm »
Ed30 or gti
Offline QD MBE
  • -Receive: 102
« Reply #4 on: November 05, 2011, 06:46:53 pm »
Take the map off, revert to STD and do some logging with VCDS.  If you don't have the cable, look in the VCDS section and find someone close to you who may assist.
Don't write off the Turbo yet, lots of other possibles.  The BF map is renown for being annoyingly playful.
Offline b21playa
« Reply #5 on: November 06, 2011, 05:55:09 am »
Offline edd666999
  • -Receive: 89
« Reply #6 on: November 06, 2011, 06:01:12 am »
Get it logged standard, if its ok, you might be having the same issue i did with the BF map.
Mine would over boost, then just die around 4k, changed to REVO and no isssues
Offline b21playa
« Reply #7 on: November 06, 2011, 10:42:15 am »
What sort of boost should it be requesting and making?
Offline b21playa
« Reply #8 on: November 06, 2011, 12:12:34 pm »
Just going to do this now
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« Reply #9 on: November 06, 2011, 01:21:50 pm »
What where the finding of the log?
Is the ecu asking for the load and the hardware not giving it, ie N75 duty cycle 95%+
I would not fit a new turbo yet, not until you know 100% what this issues are.  We use scopes to look in to the turbo via the lambda boss and the DV location.
I have also found the D valves to leak and bleed boost off.
01455 617233
Offline b21playa
« Reply #10 on: November 06, 2011, 07:51:56 pm »
Can't post Csv files here.
Nick, if I send them to you, could you have a look?
Car definately much slower without bluefin on though
Offline gillm
« Reply #11 on: November 06, 2011, 07:59:16 pm »
im going threw the same issues as you at the mo but mine is a different turbo . boost to 5 psi then nothing threw the rev range , im hoping its something simple but i fear its the turbo :( as for removing them i found it a right pain when doing my swap . hope its something simple . on std ko3 sometimes the manifolds crack which could be your problem . i have a ko3 in the loft if needed
west tuned gt28 @ 340hp
Offline b21playa
« Reply #12 on: November 06, 2011, 08:55:57 pm »
I guess you've changed the pcv and divertor valve?
What turbo you got? Ko4/hybrid?
Out of interest, what was with your ko3?
Offline gillm
« Reply #13 on: November 06, 2011, 08:57:45 pm »
i have a gt28 , i have the pcv fix and using a completly different dv set up , nowt wrong with my old turbo just upgraded
Offline b21playa
« Reply #14 on: November 06, 2011, 09:14:47 pm »
How much would you want?
