Author Topic: Changing turbo - low boost  (Read 12992 times)
Offline gillm
Re: Changing turbo - low boost
« Reply #15 on: November 06, 2011, 09:24:37 pm »
i put it on ebay tonight for 200 quid mate
west tuned gt28 @ 340hp
Offline b21playa
« Reply #16 on: November 07, 2011, 03:22:56 pm »
How hard is it to change over the turbo?
Any guides?
« Reply #17 on: November 07, 2011, 03:44:53 pm »
If you have access to a lift then the replacement isn't too bad if you have the tools. It's possible to do with the car on axle stands but I wouldn't recommend it...
Offline b21playa
« Reply #18 on: November 07, 2011, 10:10:58 pm »
What where the finding of the log?
Is the ecu asking for the load and the hardware not giving it, ie N75 duty cycle 95%+
I would not fit a new turbo yet, not until you know 100% what this issues are.  We use scopes to look in to the turbo via the lambda boss and the DV location.
I have also found the D valves to leak and bleed boost off.
Please see links to logs
With Bluefinhttps://docs.google.com/spreadsheet/ccc?key=0AilKf7s4AxAOdE1NVFVndDZOMTBpWEZQRmhPa1pHb0E
Back to standardhttps://docs.google.com/spreadsheet/ccc?key=0AilKf7s4AxAOdFRxdWhuNTFsLTc2UTNTczRNelJCaUE
Offline b21playa
« Reply #19 on: November 10, 2011, 04:39:38 pm »
I'm going to get the car in the ramps on Saturday to check all pipe work and the divertor valve. I'm hoping it's just something simple
Had jody at midlandvw look at the logs, he says on standard map it seems to be boosting ok and meeting the request, but mapped it doesnt
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« Reply #20 on: November 11, 2011, 12:01:34 pm »
From what I can see both tuned and stock maps are making the same top end load.  What fuel are you using?
We are based in the Midlands you more than welcome to pop down so i can do a log and visual check for you.
01455 617233
Offline b21playa
« Reply #21 on: November 11, 2011, 04:37:53 pm »
Car is always ran with either v-power or tesco momentum.
Please check pm
Offline b21playa
« Reply #22 on: November 13, 2011, 12:27:13 am »
Leak found in  pipe fittings to the original intercooler, they were missing the o-rings , causing boost leaks. It looks like when the twintercooler was fitted they left the rings out
New o-rings fitted and the car feels a lot better
Will get some logs done in the morning
Offline gillm
« Reply #23 on: November 13, 2011, 11:58:10 am »
thats great news , which mine was that simple
Offline b21playa
« Reply #24 on: November 13, 2011, 12:16:28 pm »
I was over the moon, pulls a lot harder, wants to spin the wheels every time I floor it
Offline b21playa
« Reply #26 on: November 13, 2011, 02:56:14 pm »
Is this a stage 1 map?
Offline b21playa
« Reply #27 on: November 13, 2011, 09:04:33 pm »
Think it's a stage 2, was already done before I got car
Offline edd666999
  • -Receive: 89
« Reply #28 on: November 15, 2011, 05:54:14 am »
New log
https://docs.google.com/spreadsheet/ccc?key=0AilKf7s4AxAOdDZ4aXc4ZFo3MlJLd2Q1b0VsTzJJMHc&hl=en_US#gid=0
That look almost identical to the map they sent me. Overboost pretty much all the time.
Basically stage 1 bluefin is great, they never, after 17files got it to actually run correctly on my car. Revo was perfect 1st time.
I am however not exactly qualified to say its defo the map thats causing your issue could be many other things im sure.
http://www.mk5golfgti.co.uk/forum/index.php/topic,18519.0.html look at my post.
« Last Edit: November 15, 2011, 06:04:41 am by edd666999 »
Offline R-tech-Nick
  • -Receive: 30
« Reply #29 on: November 17, 2011, 10:57:09 pm »
New log
Superchips "lets try that" desktop remapping vs  Revo actuall real time "tuning"
Ever wonder why superchip tune every car out there, and Revo stick with just VAG (and ME9 Ford).. :wink:
01455 617233
