Author Topic: Changing turbo - low boost  (Read 13447 times)
Offline acko2204
  • -Given: 19
Re: Changing turbo - low boost
« Reply #30 on: February 07, 2019, 10:30:46 pm »
What where the finding of the log?
Is the ecu asking for the load and the hardware not giving it, ie N75 duty cycle 95%+
I would not fit a new turbo yet, not until you know 100% what this issues are.  We use scopes to look in to the turbo via the lambda boss and the DV location.
I have also found the D valves to leak and bleed boost off.
Should all N75 duty cycles request 95% + And then start declining as boost is applied
