Author Topic: ECS clutch bleeder block?  (Read 5433 times)
Offline gazbutS3
« on: November 05, 2011, 10:17:45 am »
Anybody tried this, I get a slight leak from my standard unit only on trackdays, must be when the fluid gets really warm, was thinking of changing it to this part rather than buying another std 1, anybody any thoughts??
http://www.awesome-gti.co.uk/product.php?xProd=42015
Offline vRSAlex
  • -Receive: 253
Re: ECS clutch bleeder block?
« Reply #1 on: November 05, 2011, 10:55:31 am »
I'm going to order one of these on Monday.  I will let you know how I get on.  The standard part won't be much cheaper so its always worth upgrading to a better part.
Follow AKS tuning on Facebook
Offline gazbutS3
« Reply #2 on: November 05, 2011, 11:16:33 am »
my thoughts exactly :happy2:
« Reply #3 on: November 05, 2011, 11:44:44 am »
Interested in that now too  :smiley:
Offline vRSAlex
  • -Receive: 253
« Reply #4 on: November 07, 2011, 12:59:41 pm »
Not in stock at awesome. Going to be 2 weeks wait. Rubbish!
« Reply #5 on: November 07, 2011, 01:02:53 pm »
In time 4 payday lol :)
Offline vRSAlex
  • -Receive: 253
« Reply #6 on: November 07, 2011, 01:33:14 pm »
I'm going to see if my old buddies at ecs can send me one direct.
Offline vRSAlex
  • -Receive: 253
« Reply #7 on: November 07, 2011, 05:16:51 pm »
Comes to about £65 if you order direct.  I think I can wait a couple of weeks!
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #8 on: November 07, 2011, 08:48:32 pm »
wow, cool didnt even know they existed   :happy2:
go for it. they did a valve delete on the E46 M3 and everyone used to rave about it, improved the gearchange no end.
Red ED35 5dr DSG
BLOG | BUILD
« Reply #9 on: November 17, 2011, 12:11:39 pm »
Easy to fit?  Is added to the evergrowing list
Offline vRSAlex
  • -Receive: 253
« Reply #10 on: November 17, 2011, 12:47:35 pm »
Easy to fit.  Then just needs the clutch bleeding.
Still not in stock with Awesome.  Looking at another 2 weeks.
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #11 on: October 20, 2012, 11:07:30 pm »
hi alex, would this part be any use to helping cure my slow to return clutch?
Offline gazbutS3
« Reply #12 on: October 21, 2012, 08:31:20 am »
 Alex fitted this on my car when he swapped the gearbox, he commented that the fit wasn't great as the body of it needs to be fettled as it was fouling the gearbox casing. It's been fitted for about 5k now and the only comment I can make is it has cured the leak I used get on track days  :smiley:
Offline vRSAlex
  • -Receive: 253
« Reply #13 on: October 21, 2012, 08:18:58 pm »
Removing the internal restrictor does the same job and at no cost.
Your fault may also be a fooked clutch line.
Try the free mod first.
Offline Pirelli Paul
  • -Given: 64
« Reply #14 on: October 22, 2012, 06:24:22 am »
I installed one in my car, seems OK and we pressure tested it to 2 bar on the car with no leaks. One side was a little tight so I had to run a drill down the initial larger bore opening that slides over the clutch bearing arm to de-burr it and also it was fouling the bell housing slightly and making it sit at an angle so some grinding was done on it to get it to sit straight (The origional one has a round profile this one is square).
Apart from that it went on fine and the clutch seems to have a better feel to it. Relatively cheap and a recommended upgrade but I do feel that a bit more effort could of gone into the design so it fitted better as they could of machined a couple of mm off the sides to get it sitting better without effecting its strength.
Cheers Paul
« Last Edit: October 22, 2012, 06:27:31 am by Pirelli Paul »
