Author Topic: LED Glow  (Read 4070 times)
Offline Zaf2616
LED Glow
« on: November 06, 2011, 12:38:11 am »
Anyone experienced this with interior replaced LED bulbs?
Seems light there is some voltage running through them even though there not on, anyway to sort this out?
Cheers,
Zaf
Offline Weston
Re: LED Glow
« Reply #1 on: November 06, 2011, 12:40:08 am »
You need to use canbus safe bulbs then they won't do this. Do they work ok when switched on?
GTI going...
Offline Zaf2616
Re: LED Glow
« Reply #2 on: November 06, 2011, 12:41:20 am »
Yes mate they work fine, these are canbus bulbs tho, back ones do it an all
Re: LED Glow
« Reply #3 on: November 06, 2011, 09:19:31 am »
I just bought a set and have my fingers crossed they don't glow? will update when they arrive
Re: LED Glow
« Reply #4 on: November 06, 2011, 10:37:32 am »
Zaff which bulbs did you buy, i got the kit from partsulike
Offline Zaf2616
Re: LED Glow
« Reply #5 on: November 06, 2011, 10:38:59 am »
Cheers Mike,
Although when I set the light position to "Off" completely (not come on when open doors) there is no glow at all
Offline Zaf2616
Offline VRSerious
Re: LED Glow
« Reply #7 on: November 06, 2011, 11:38:55 am »
Unless I'm being daft, the cambus dose not monitor your interior bulbs, so no need for "canbus friendly"
mkII VRS Octavia in Silver, Shark stage 1,Milotec lower front grill, private plate, EVOMs CAI, LED side and plate lights, de-badged, version D divert valve, BSH catch can, retro fitted parking sensors, cat back ss exhaust, Neuspeed Hi Flo intercooler pipe, S3 consoles/bushes,  Cupra 345mm front brakes + Goodridge braided hose, Bilsten B12
Re: LED Glow
« Reply #8 on: November 06, 2011, 11:39:46 am »
I thought that but it's the fact they have built in resistors I think. Maybe wrong.
Offline vwrascal
Re: LED Glow
« Reply #10 on: November 06, 2011, 12:03:49 pm »
I have led interior wedge bulbs, i get no glow at all! Also the interior bulbs are not monitered apart from the footwell lights! Only canbus leds needed for footwell!
Otherwise you get this
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 AB    HW: 3C8 937 049 AB
   Component: Bordnetz-SG     H57 3204
   Revision: 00H57000    Serial number: 00000003333549
   Coding: E58D1F370004100000140000140000008009FF075C00000C000000000000
   Shop #: WSC 00152 210 91233
   VCID: 71ED83811132
   Part No: 1K2 955 119 E
   Component: Wischer 190606 020  0501
   Coding: 00038805
   Shop #: WSC 00152
   Part No: 1K0 955 559 AE
   Component: RLS     180606 014  1201
   Coding: 00208933
   Shop #: WSC 00152
2 Faults Found:
00061 - Footwell Lights
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 54
                    Mileage: 67580 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.35 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02390 - Control / Regulation for Ambience Lighting (E400)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 54
                    Mileage: 67580 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.35 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Offline vwrascal
Re: LED Glow
« Reply #11 on: November 06, 2011, 12:07:55 pm »
Re: LED Glow
« Reply #12 on: November 06, 2011, 12:09:15 pm »
Don't think the poverty spec golf Leon has footwell lamps lol. Or puddle lights :fighting:
Offline Zaf2616
Re: LED Glow
« Reply #13 on: November 06, 2011, 12:09:42 pm »
Mike try this one on your phone
http://item.mobileweb.ebay.co.uk/viewitem?itemId=260779065862&cmd=VIDESC
No fault codes show on mine and I originally did think it was the fact they werent canbus so bought canbus ones but same thing
Offline daveangel
Re: LED Glow
« Reply #14 on: November 06, 2011, 07:36:45 pm »
i have led puddle and side lights, can freindly,  i noticed they occasion error all together maybe when the batt volts are little low?
anyone else seen this?
