Author Topic: Fitting New Alarm  (Read 12248 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Fitting New Alarm
« Reply #15 on: June 04, 2016, 11:21:43 pm »
May need coding with vagcom.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #16 on: June 05, 2016, 12:02:02 am »
When i replaced mine i didnt need to code it.
Sent from my SM-G928F using Tapatalk
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #17 on: June 05, 2016, 12:41:25 am »
Maybe a faulty used siren?.
Offline hussnainh8
« Reply #18 on: June 05, 2016, 05:36:56 am »
Yes maybe it was faulty.. can I confirm that buying a different revision alarm wont cause any incompatibilty issues? The alarm I took out of my car has the code 1K0 951 605A and the one I tried to replace it with has the code 1K0 951 605C but that didnt work .. literally no sound.. Seller agreed for me to return it but I am not sure if I should buy another C or try find the A revision? The A revision is priced higher, nearly double the price and I dont want to take the risk if it wont work :( ...
What about the D revision? Would that work? :S cant see why that would work if the C revision didnt :( These different revisions are really doing my head in :(
Any one ???
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #19 on: June 05, 2016, 10:35:53 am »
Or check the fuse for the alarm
Offline hussnainh8
« Reply #20 on: June 05, 2016, 11:12:34 am »
The fuse is working.. checked the continuity of the fuse using a multi meter and checked if the link between the prongs is broken which it is not. I believe it is fuse 35, 5a fuse in the fuse box next to driver? If so then it is not faulty. So should I buy another C revision or the D revision or should I keep looking out for a A revision?
Thank you.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #21 on: June 05, 2016, 12:45:31 pm »
Yes. Its fuse 35.
I bought mine from here
http://www.ebay.co.uk/itm/321546915933
Been fitted for 18 months now with no issues
Offline hussnainh8
« Reply #22 on: June 05, 2016, 04:35:05 pm »
That link doesnt say if it is compatible with my Golf MK5 2004 and if it is compatible with the A revision alarm as my old unit is A revision? :( im stuck as to if i shouls now get the C revision again and HOPE it works or go for the A revision?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #23 on: June 05, 2016, 05:34:42 pm »
If in doubt get the A as there are plentyout there.
I used a C on my mk1 tt and it worked fine so maybe the one you've got is faulty too?.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #24 on: June 05, 2016, 06:04:19 pm »
A is the older version which i had, i changed it to a C and had no problems
Offline hussnainh8
« Reply #25 on: June 05, 2016, 08:00:13 pm »
Hmmm okay I made my decision.. I am going to buy another C revision and just cross my fingers it works.. yes maybe it was faulty as the seller agreed to a return straight away.. Just hope it works when I buy it .. I dont want to buy A revision because the problem will happen again and with C revision there is less chance. C revision it is! Thanks guys.
Offline hussnainh8
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #27 on: June 05, 2016, 08:19:25 pm »
Why :slap: just get the A and stop you're messing around. The one you just linked is horrible.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #28 on: June 05, 2016, 08:24:50 pm »
I still think a 1K0 951 605C will work although must be working.
are you local to London lol
Offline hussnainh8
« Reply #29 on: June 05, 2016, 08:27:53 pm »
I am in Peterborough aha .. I have just paid for another C revision
http://www.ebay.co.uk/itm/111874934217?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
