Author Topic: r32 rear disc upgrade  (Read 1006 times)
Offline daveangel
« on: November 07, 2011, 06:37:18 pm »
anyone upgraded a gti to r32 rear disc's?
do the oem heat guards fit?
done a load of reading and so far came up with no.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: r32 rear disc upgrade
« Reply #1 on: November 07, 2011, 06:52:29 pm »
Yes they fit (but need the R32 carriers and calipers too). Splash guard can be re-used just needs bending back a little.
Offline QD MBE
  • -Receive: 102
« Reply #2 on: November 07, 2011, 07:01:54 pm »
As the gaffer says.  Yes they can be used, just takes a small tweak.
I was one of the first to fit S3/R32 rears to a Gti.  I tried the S3 guards, and they just do not fit, could only get one screw in correctly.
Offline daveangel
« Reply #3 on: November 07, 2011, 07:06:59 pm »
Thanks guys. Soooooooo
You can bend the gti's back a bit
The s3 don't fit
What about the actual r32 ones? I've read they have 4 holes to mount vice 3?
Offline QD MBE
  • -Receive: 102
« Reply #4 on: November 07, 2011, 07:21:35 pm »
I wouldn't bother looking any further.  Just fit the discs/calipers etc, and tweak the guards to provide clearance.  I ran this set-up for ages, then when removed tweaked them back into shape.  All good.
Offline Bikerz
« Reply #5 on: November 07, 2011, 07:32:53 pm »
Does the R32 have a larger master cylinder?
Offline QD MBE
  • -Receive: 102
« Reply #6 on: November 07, 2011, 07:39:54 pm »
Fairly sure they are the same.
