Author Topic: Ekta help Required - Dogbone mount Bolt spec  (Read 3353 times)
Offline QD MBE
  • -Receive: 102
« on: April 09, 2009, 06:34:35 pm »
I have fitted my Dogbone mount, and re-used the old bolt.  Looking at it, and using my engineering experience, I don't believe it to be a stretch bolt.
One thing that does concern me, is the length of the bolt is not enough, given the extra thickness of the DB bush, and the large washer.
Can someone look at ekta for me, and perhaps post up a pic of the bush assembly, and bolt part number.  In the spec it may give the bolt length, thread size and pitch.  I could do this at home, but it would mean getting under and removing the bolt agian.
I am going to look into getting a proper High tensile steel bolt, the correct length.
Cheers in advance.
Dave
 :happy2: :happy2:
« Last Edit: April 09, 2009, 09:50:28 pm by stokeballoon »
Offline gazbutS3
Re: Dogbone mount Bolt spec
« Reply #1 on: April 09, 2009, 07:29:22 pm »
I remember when I fitted the ECS bush, the bolt supplied had a higher tensile strength than the original, its stamped on the head, so maybe worth looking at that as well.
I think your right to be concerened about the length as there has been issues with the bolt pulling out of the threaded insert in the mount and stripping the thread, if the bolt is not long enough it could happen easier, all my opinion of course :smiley:
Offline QD MBE
  • -Receive: 102
Re: Ekta help Required - Dogbone mount Bolt spec
« Reply #2 on: April 09, 2009, 10:12:20 pm »
Cheers Gaz, i think I will have to remove the old one and gauge it up, or ask the parts dept for help.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #3 on: April 09, 2009, 10:22:04 pm »
Is it any of these Dave?
[pdf]http://www.mk5golfgti.co.uk/forum/downloads/stoke.pdf[/pdf]
Offline keith
« Reply #4 on: April 09, 2009, 10:25:05 pm »
Is the whole point of the replacement dogbone mount that its an uprated bolt?
the old one isn't up to much so i'd get the new one back in.
Offline QD MBE
  • -Receive: 102
« Reply #5 on: April 09, 2009, 10:40:23 pm »
Steve you star, it is number 30.  What does it say in the legend?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #6 on: April 09, 2009, 10:47:11 pm »
Here is all the details on part 30
Offline QD MBE
  • -Receive: 102
« Reply #7 on: April 13, 2009, 08:19:24 pm »
Well i removed the bolt, and replaced it with a bolt i had in the drawer.  I had some M14 x 1.5 80mm long bolts in the garage.  The bolt I fiited is not a stretch bolt, and I torqued it up to 100Nm + 90 degrees, as per the Maint manual (thanks T_T).
The original bolt in my opinion is not a stretch bolt, but it is definetly about 5-8mm too short, due to the extra thickness of the bush, and washer.
I think the bolt I used came from a suspension part (don't ask where, as i stripped them down a while ago)off the S3 hubs I bought.
Cheers for the help with the Etka Steve.
