Author Topic: How to: repair 3 door sliding seat problem  (Read 124723 times)
Offline w80ody
« on: November 09, 2011, 04:54:42 pm »
Is your 3door seat folding but not sliding forward to let people in the back of the car? I had this problem for the past 3 years and final got round to fixing it.
Parts required:
The part is listed on ETKA as “holder for bowden cable”
Passenger side part number – 1K3 881 132 B
Drivers side part number -  1K3 881 132 C
Lastest Price (Jul 2014): £0.67
(New part shown on right here)
Tools required:
Torch
Slot screwdriver or similar
Small pair of fingers!
The guide shows this part being replaced on the passenger side seat, drivers side is the same. I must say that by the close up pictures of my seat rails they look filthy….I blame the camera!!
For ease of access slide the seat as far forward and jack the height adjuster up as high as it will go. Highlighted is the mechanism were interested in.
I did the same with my driver’s seat and tilted/slide it a couple of times to understand how handle and tilting action adjusts the cable which attaches to the seat runner.
When the seat is tilted forward the cable comes into tension and pulls on a catch mounted on the rear outer seat rail which releases the seat allowing it to slide forward.
The issue I had was when tilted this cable would not be in tension as the clip which keeps it in tension was broken.
To release the cable, unscrew the screw tensioner shown and pop it out of the bracket.
It can then be unhooked from the guide hole on the left hand side.
Under the back adjustment winder you can trace the cable. To aid access the plastic cover pictured below at the back of the seat slides down and then is bent back and down out of the way. (Thanks Huntsman - made it a bit clearer with your description)
My cable guide was already out the clip but you may have to remove yours. The guide then can be pulled off cable.
Old and new cable guide, you can see the design change on the left to improve the strength of the hooked lug.
Attach new guide to the cable.
The bottom of guide hooks onto seat base.
Circled is where the guide clips into position.
A screwdriver is handy here to pop the clip back into position.
Refitting the cable is then the reversal of the previous steps shown, adjusting the plastic tensioner screw till the seat slides smoothly without making a ratchey noise.
Whilst you are working at your seats, here’s an easy way to make some cash…..
One M10 spline + 5mins removing your seats and viola
£4.64 and a milkbar button  :smiley:
« Last Edit: September 26, 2014, 02:27:54 pm by w80ody »
Offline lee_
Re: How to: repair 3 door sliding seat problem
« Reply #1 on: November 09, 2011, 05:07:15 pm »
Nice write up, been meaning to sort mine since I bought the car!!
Offline john87
  • -Receive: 53
« Reply #2 on: November 11, 2011, 12:29:20 pm »
Nicely done..continuous improvement at its best  :happy2: my passenger seat makes a ratchety sound when sliding forward (seat folded up) - could this mean that the mechanism is close to breaking point?
« Reply #3 on: November 11, 2011, 03:20:57 pm »
Great write up mate  :congrats:
Great photo'd and clear instructions  :happy2:
It's people like you that make forums such an amazing place! With these sort of tutorials we save so much money. I bet it would have been £50+ to have repaired at the stealers :wink:
The How-to's on this forum must have saved me £££'s plus it's a good feeling when you gain the confidence to do the job yourself. Also if you come across any hurdles, there's always forum members online ready to help.
Keep em coming  :notworthy:
Offline Betty02
    • iBett
« Reply #4 on: November 15, 2011, 09:42:23 am »
Post thanked! Just done this today! Really really impressed with actually how easy of a solution it is! For the sake of 55p I also changed my driovers side and they both now slide like there ice on glass!
Quote
Yes this is what my drivers seat did so I changed that as well and it fixed that, another free alternative is tighten up the cable by twisting the black nob in picture 3, but for 55p I would replace the whole thing as these ones seam a hell of a lot stronger then the old ones!
ADMIN NOTICE: Please do not use the site for advertising!
Offline w80ody
« Reply #5 on: November 15, 2011, 05:20:10 pm »
Cheers for the thanks folks  :happy2:
Thought I’d take the time to write the guide as I’m sure there’s loads of golfs out there with the same problem.
Took me 3 years of friends complaining about getting in the back for me to get round to doing this but well worth it. If you have the same issue you’ve no excuse for not doing it when it’s as simple and cheap as this!
Its good to see that VW realised the flaw and beefed up the new design.
Offline ConeKiller
« Reply #6 on: November 15, 2011, 11:23:46 pm »
thanks for the write up dude think ones gone on mine :(
Offline Meallbhan
« Reply #7 on: December 04, 2011, 08:36:51 pm »
I've been wondering wy the passenger seat worked but the drivers side didnt.  I thought it was the wee metal slidey thing that can move.  Right, off to VW tomorrow!  Bet they dont charge me 55p!!
Offline HDautos
« Reply #8 on: November 06, 2012, 08:37:00 pm »
Used this guide to repair both of my seats they now slide like new and was a very cheap repair job :D
Offline driver rider
  • -Given: 18
« Reply #9 on: November 06, 2012, 09:02:04 pm »
w80ody
 :notworthy: :notworthy: :notworthy: :notworthy:
Im going STRAIGHT to my dealer on friday and fitting itsaturday first thing and sorting my seat. People like you make this forum invaluable.  I will do both seats.  It's a no brainer the clip has been beefed up big time.  Good to see VW have acknowledged it and sorted it.  Its so annoying not being able to slide the passenger.  Once sorted my seat.  I'll be sending thanks your way. Top man! :happy2:
3 Door GTI Black, Cruise Control, DSG, Factory Tints, Folding Mirrors, Heated Seats, Highline Display, Leather, Monza II's, MFSW, Parking Sensors, Puddle Lights,  Xenons,
To be fitted....Bluetooth,DVB-T, MDI, RNS510, Stage one (opinions much appreciated)
Offline rsrob
« Reply #10 on: April 26, 2013, 12:00:28 pm »
Nice guide sorted mine yesterday on my driveway.
Offline 4dyctdi
« Reply #11 on: April 30, 2013, 05:51:14 pm »
Excellent guide thank you
Offline brogdog
« Reply #12 on: May 16, 2013, 05:41:37 pm »
Awesome mine stopped working this morning ill get to it :)
Offline jonnboyy69
« Reply #13 on: May 20, 2013, 04:14:29 pm »
Just ordered mine today........now 62p each!  :wink:
3dr black 56 GTi, Rcd510 DAB + Blaupunkt sharkfin finally completed.....
Offline GTIite
  • Build it.. don't buy it!!
« Reply #14 on: May 20, 2013, 08:24:33 pm »
My seats have been like this for the last 2 years and I have never got round to finding out why!! lol. Thank you!!!  :happy2:
I have ETKA and ELSA - Happy to help if anyone needs anything. Instagram - @f11tvw
Rotiform VCE's : US Spec Rear Bumper : Colour Coded Side Skirts : US Grill : De-Wipered : Revo Stage 2+ Map : Revo Intake : Revo throttle pipe : THS Intercooler : K04 Conversion : Milltek Cat Back + Pipwerx Decat : Sachs Stage 3 Organic clutch + Single mass flywheel : Quaife ATB Differential : S3 Brakes + Vagbremtechnic discs : Full SuperPro Bushes : SuperPro ARB
