Author Topic: New laptop battery  (Read 2384 times)
Offline gazbutS3
New laptop battery
« on: November 11, 2011, 05:47:22 pm »
The battery on my Sony VAIO has croaked, the Sony ones are over 100quid, anybody any other suggestions, am I right to be wary of the cheap internet copies? are they gonna fry my laptop???
Re: New laptop battery
« Reply #1 on: November 11, 2011, 05:57:30 pm »
Do you actually go 'mobile' much with it Gaz?  I use all my notebooks in the house with no battery and off the mains.
I opt for the upgrade cell when speccing / buying a laptop and just before warranty expires see if I can get a replacement (as advised by a tech assistance at laptop manufacturer!  :surprised:) as a spare.
Mike
Offline gazbutS3
« Reply #2 on: November 11, 2011, 06:04:27 pm »
yes do go mobile, and want to use vagcom for more logging so do need a battery really
« Reply #3 on: November 11, 2011, 06:10:16 pm »
Got ya.  If it's a hi end notebook Id personally be weary of cheap cells.  Ive started using Nats Netbook for logging as the battery is loads better than my current Xps and her gash Dell
Offline gazbutS3
« Reply #4 on: November 11, 2011, 06:23:35 pm »
theres a lewd comment in there but I'll leave it  :smiley:
so you reckon its best to stump up for the genuine article
« Reply #5 on: November 11, 2011, 06:29:49 pm »
Got ya.  If it's a hi end notebook Id personally be weary of cheap cells.  Ive started using Nats Netbook for logging as the battery is loads better than my current Xps and her gash below standard Dell
 :signLOL:  I have a feeling Ifti may have a suggestion if aftermarket replacements are available a bit cheaper  :happy2:
Offline gazbutS3
« Reply #6 on: November 11, 2011, 06:33:00 pm »
cheers mate :happy2:
Offline m4t_lee
« Reply #7 on: November 11, 2011, 06:59:05 pm »
Have you tried exercising the battery? Run it right down till it turns itself off, then charge it fully then repeat? May have to repeat 5 or 6 times but I think there are only 2 or 3 batteries this hasn't worked on for me (done loads too)
06 Shadow Blue GTI
Offline gazbutS3
« Reply #8 on: November 11, 2011, 07:17:41 pm »
it holds no charge at all pal :sad1:
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #9 on: November 11, 2011, 07:19:51 pm »
had same issue with my old sony gaz, won't even boot on battery  :fighting:
« Reply #10 on: November 11, 2011, 07:22:56 pm »
My vaio did the same thing and has to be plugged in to work
Offline gazbutS3
« Reply #11 on: November 11, 2011, 07:32:17 pm »
did u try a new battery Matt, maybe its the charging system that goosed???
« Last Edit: November 11, 2011, 07:38:24 pm by gazbutS3 »
« Reply #12 on: November 11, 2011, 07:34:24 pm »
Bloody replacement chargers arent cheep, last one I got from Maplins was £70 - £80  :fighting:  Had changeable ends and changeable power levels (sure it was voltage but remember Amps were important) to work with different brand laptops though  :happy2:
« Reply #13 on: November 11, 2011, 07:38:49 pm »
the power cable also died after a few years but could do with a new battery for vag com duties but like you £100 for them is nuts
« Reply #14 on: November 11, 2011, 07:44:14 pm »
An alternative would be to get a 12V inverter that you plug into the car lighter (if you has one) and just run the laptop off the inverter. A bit clumsy but it's cheaper than getting a £100 battery.
You'll have to remember to shut down windows before turning off the ignition as both sleep and hibernation functions need a power source.
