Author Topic: RCD 510 how to reboot?  (Read 6373 times)
Offline gizmo68
  • We're here for a good time, not a long time
« on: November 12, 2011, 01:21:13 pm »
I have just tried to reboot a RCD 510 unit with the ,<> & top right button, but as it has a 6 CD changer built in all this does is put it into the "CDC Transport Mode" (this locks the CD changer in place for transportation)
How do I force a reboot? is removing the battery the only way?
VCDS HEX-NET & VCP owner (covers all VAG cars)
(PM me if you require VCDS or VCP coding or scanning in Kent)
Offline brookesb32
  • -Given: 59
  • -Receive: 75
Re: RCD 510 how to reboot?
« Reply #1 on: November 22, 2011, 06:00:33 pm »
Have you tried the reset to factory settings function to see if that helps?
Offline gizmo68
« Reply #2 on: November 22, 2011, 08:08:23 pm »
No we didn't, it turned out that after fitting the bluetooth module a reboot was not necessary anyway  :happy2:
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #3 on: November 22, 2011, 08:30:56 pm »
Happy days!
Was the Bluetooth module expensive/hard to do? Kinda fancy it now after I installed the RCD 510 :)
Offline gizmo68
« Reply #4 on: November 22, 2011, 08:37:13 pm »
Can't help you with that I'm afraid as I only coded the car.
