Author Topic: Replacing a key casing  (Read 1359 times)
  • -Receive: 291
« on: November 12, 2011, 10:30:15 pm »
The little metal loop at the top of the key has broken off and the buttons just don't work as well. Was planning on replacing the key. Can I just swap the blade and electronic gubbins over to a new key?
Re: Replacing a key casing
« Reply #1 on: November 12, 2011, 10:45:27 pm »
There's one for sale in Car parts cheap and offer to have it coded I think if bought  :happy2:
« Reply #2 on: November 12, 2011, 11:18:52 pm »
Never done it before but I can't see why you can't simply transfer the internals of the old fob into a new one.
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #3 on: November 12, 2011, 11:38:22 pm »
Certainly can, did it as soon as I bought my car. Just bought the case from eBay, took it all apart and replaced the inners and the key part with mine. Just need to get the spring in correctly otherwise the key doesn't spring out quite right, but easy to get right.
Key just prises in half using a small flat blade twisted 90 degrees in the slot under where the key rests when closed. The other other thing I had to do on mine was to put some glue when the little transponder thing goes (looks like a small tube) as the new case did not have a piece of plastic to stop it moving). There is also a small screw under the VW badge on the back which you need to unscrew to get the top half to separate
Dead easy though and came with a new VW badge for the back to stick on.  :happy2:
Such as this
http://www.ebay.co.uk/itm/180754423062?ru=http%3A%2F%2Fwww.ebay.co.uk%3A80%2Fsch%2Fi.html%3F_nkw%3D180754423062%26_sacat%3D0%26_odkw%3D1807544%26_osacat%3D0%26_trksid%3Dp3286.c0.m270.l1313%26_fvi%3D1&_rdc=1#ht_2956wt_1210
« Last Edit: November 12, 2011, 11:44:48 pm by brookesb32 »
  • -Receive: 291
« Reply #4 on: November 12, 2011, 11:43:34 pm »
Did you have to reprogram the key or the immobiliser?
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #5 on: November 12, 2011, 11:45:59 pm »
Nope as just moved over all the inners so it's just a new skin  :smiley:
Oh and there are OEM ones on eBay which is what I bought, above was just first one I came to that explained well
« Last Edit: November 12, 2011, 11:48:08 pm by brookesb32 »
