Author Topic: vw badges  (Read 5946 times)
Offline candy turbo
vw badges
« on: April 11, 2009, 07:46:12 am »
any one have insrtuctions how to remove front and rear vw badges ? i want to spray mine ?cheers
Re: vw badges
« Reply #1 on: April 11, 2009, 03:47:01 pm »
Offline candy turbo
Re: vw badges
« Reply #2 on: April 11, 2009, 09:32:13 pm »
cheers mate , front is quite easy rear dont look so simple !!!!!
Re: vw badges
« Reply #3 on: April 11, 2009, 09:48:06 pm »
I did the rear in a couple of hours. You just need to be brave taking the rear trim off.
Are you just wanting to take the rear chrome part of the badge off or all the latch mechanism?
If you just want the chrome VW badge off then you just tilt the latch up and slide a thin piece of plastic into the join between the latch and the chrome badge, GENTLY move the plastic (could use a credit card) from side to side and eventually the badge will come off.  :happy2:
Offline candy turbo
Re: vw badges
« Reply #4 on: April 12, 2009, 08:20:23 am »
cheers hurdy ,ill try that , if it breaks which bit will i need to replace??
Re: vw badges
« Reply #5 on: April 12, 2009, 09:11:33 am »
It shouldn't break as a few of us have had to take them off when we had the CF ones and I'm not aware of any problems?
Offline candy turbo
Re: vw badges
« Reply #6 on: April 12, 2009, 09:21:39 am »
is it held on the same as the front one ? with the silver bits tight fitting in to smaller holes ?
Re: vw badges
« Reply #7 on: April 12, 2009, 09:30:59 am »
Yes, that and small ridges around the inside which clip it onto the plastic moulding.
Offline candy turbo
Re: vw badges
« Reply #8 on: April 13, 2009, 09:40:17 pm »
managed to remove my vw badges today ready for spraying BUT  using great advise from hurdy removing the rear one with a credit card i removed the mount which is doudle sided taped to the latch ! thats ok !!but had broken a few of the locating lugs off the back of the chrome badge !!! bum !  so can i buy just the chrome badge from the stealers ?????????  :ashamed:
Re: vw badges
« Reply #9 on: April 13, 2009, 09:52:25 pm »
No mate, we'd have told you to do that in the first place if you could!  :wink: :signLOL:
Offline candy turbo
Re: vw badges
« Reply #10 on: April 13, 2009, 10:00:42 pm »
cheers , well its not beyond repair only a fwe of the lugs broken so with a little d/s tape will be ok <  how much do the carbon ones cost ?
Re: vw badges
« Reply #11 on: April 13, 2009, 11:10:08 pm »
We all bought them in a group buy from the TT Shop, but you still have to send in your original chrome one as they use it as a base. If you don't send in the badge they buy a whole new latch unit and use the badge off that. My front and rear cost about £180 in total including the cost of the badges and a full new rear latch.
I still have bothe the old badges and latch if I want to return to stock. :wink:
