Author Topic: How to remove egr cooler on bkd tdi?  (Read 14289 times)
Offline mortygttdi
  • -Receive: 146
Re: How to remove egr cooler on bkd tdi?
« Reply #15 on: November 30, 2011, 08:26:42 pm »
All the EGR kits will bring the CEL on mate, it needs to be deleted from your ecu via a remap.
Darkside Developments kit is £85 but its excellent quality
Darren
that's cheaper than i was expecting  :happy2:
Excuse my ignorance, who does a egr delete remap?  :ashamed:
Are you getting it mapped out?
I already had it mapped out mate by RSTuning in Leeds, but if you can travel Darkside so the mapping aswell,
Darren
Offline GTsport
« Reply #16 on: November 30, 2011, 08:34:45 pm »
Thanks for the info  :smiley:
Something im definately going to look at doing once xmas is out the way.  Look forward to seeing the details when you've picked yours up  :happy2:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #17 on: December 11, 2012, 03:55:29 pm »
Blast from the mega past.....
Does anyone have a guide to remove the EGR?
Offline Matto
  • -Receive: 116
« Reply #18 on: December 11, 2012, 05:14:31 pm »
I don't have a guide but it's pretty easy to do. Take it you have a delete pipe to go fit? From memory tthere is 5 or 6 bolts and an electrical plus. I know one bolt goes right through the asv and egr. The only problem you will find is removing the metal pipe that connects to the egr. I had mine removed the same time as the dpf and he had to chop it in half to get it out. You will also find it will throw a fault due to the egr being disconnected.
Or you are removing, cleaning and putting it back and I've just written that for nothing  :signLOL:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #19 on: December 11, 2012, 05:55:55 pm »
Cheers for the info. I was going to buy a delete pipe but then realised the light would need to be mapped out, the cash for which i dont have at the mo so a clean will have to do  :fighting:
Offline Matto
  • -Receive: 116
« Reply #20 on: December 11, 2012, 06:18:14 pm »
You could clean it and maybe make a small gasket to slip between the egr and the feed pipe to stop it getting dirty again as a temporary measure. Although I still think it may throw a fault as its monitoring the flow. Try it and see.
