Author Topic: Cooler NGK plug?  (Read 1451 times)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Cooler NGK plug?
« on: November 18, 2011, 04:29:37 am »
Ngk says this is a cooler plug than the PFR7Q...>PFR8S8EG
It's oem on the 2010 A6 3.0 CCAA.
Anybody been told this as well when choosing a cooler plug for edition 30's tuned @ 340 to 350 bhp?
Offline 56OctyVRS
  • -Receive: 72
Re: Cooler NGK plug?
« Reply #1 on: November 18, 2011, 10:03:36 am »
If you track day your car and are always using the power then you will need a colder than standard plug at your level of tune.  Most peeps with stage 2+ / 3 on K03 that use the power go for the '8' heat range, as you have the K04 and at your level of tune, the 8 will be fine for fast road / track driving. If you just do normal local road driving the 7 will be fine.  The main reason is down to carbon build up.  If the plug doesnt get hot enough then it will build carbon up around the electrode, foul and then start running rough.  So its down to how you drive and what your needs are.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #2 on: November 18, 2011, 10:30:19 pm »
Good to know.
I usually drive sanely and open it up maybe once or twice a day.
Never tracked yet other than quarter mile.
My plugs look good when changed so; Probably best to leave it as is with '7's'?
