Author Topic: Knocking noise when steering at dead slow speed  (Read 9716 times)
Offline Mk5 GTian
  • -Receive: 37
« on: November 18, 2011, 03:58:14 pm »
I've noticed a slight knocking noise when doing a 3 point turn, or very slow full lock turn in a car park or doing a u-ey. It happens when I am turning the wheel in an anti-clockwise direction.
Does anyone have any experience of this or know what it could be? I don't hear anything in normal driving.
Cheers,
Ian
 :confused:
Re: Knocking noise when steering at dead slow speed
« Reply #1 on: November 18, 2011, 04:11:20 pm »
I get one knock noticied when reversing on full lock.
Im having geometry done soon so may upgrade the topmounts to TTRS / RS3 ones.  I have new track rod ends and will soon have new ball joints with TT lower arms.
Ill update when its cured  :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #2 on: November 18, 2011, 04:30:45 pm »
Cheers,
Ian
 :confused:
Have a read through this thread, might be your problem HTH  :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,23845.0.html
Offline Mk5 GTian
  • -Receive: 37
« Reply #3 on: November 18, 2011, 04:42:15 pm »
Brilliant, thanks for that, I'm going to get these ordered up tomorrow. Could be a cheap fix!
Looks like the bolts could be an Audi job, the shims are VW apparently.
« Reply #4 on: November 18, 2011, 04:43:28 pm »
Ian is yours one knock each time?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #5 on: November 18, 2011, 04:47:21 pm »
Glad to help :happy2: I got the whole lot from Audi, they stock all (well mine did) :drinking:
Offline seiko
« Reply #6 on: November 18, 2011, 05:14:15 pm »
could be top mounts, comman fault?
« Reply #7 on: November 18, 2011, 05:18:25 pm »
Excuse for RS3 ones  :party:
Offline Mk5 GTian
  • -Receive: 37
« Reply #8 on: November 18, 2011, 06:49:56 pm »
Yes Mike, it's once only.
« Reply #9 on: November 18, 2011, 06:50:52 pm »
Sound similar to the occasional noise I get then
Offline Mk5 GTian
  • -Receive: 37
« Reply #10 on: November 19, 2011, 04:52:43 am »
Mike, It sounds like you might have the same problem with these bolts stretching, as described previously. I'm going to buy them today and get them fitted next week, so I'll let you know if it does the trick. I do love a cheap fix!
« Reply #11 on: November 19, 2011, 07:46:01 am »
I had my Steering Rack replaced under warranty for having the same noise  :sad1:
It's quite a common thing apparently.
« Reply #12 on: November 19, 2011, 09:23:37 am »
Thank you mate  :notworthy:
Offline Little_Dave
« Reply #13 on: November 19, 2011, 08:50:18 pm »
My knocking noise is only at slow speeds when i first set off and not on full lock or the usual situations and only started happening after i got coilovers fitted and lowered, getting my top mounts and front bushes changed next week so i'll let you know if it fixes mine  :happy2:
Dave
« Reply #14 on: November 19, 2011, 08:51:33 pm »
Mine doesnt happen every time but am upgrading / replacing top mounts over xmas so will update too  :happy2:
