Author Topic: A tested and proven quick fix for rcd510/rns510 power drain  (Read 89714 times)
willni
Re: A tested and proven quick fix for rcd510/rns510 power drain
« Reply #30 on: January 31, 2017, 01:01:47 pm »
Just looked at my ebay purchase history and I bought it from sat_nav_deals
Might be worth contacting him, or eddieNL on here is a bit of an electrical whizz I believe.
Thanks! I'm gonna do the canbus upgrade on my edition 30, and probably recommend something like yours for my brother
« Reply #31 on: January 31, 2017, 01:18:08 pm »
Just be careful with 'pre-coded' CAN buses. I got one and it caused more problems than it was worth, so reverted back to the factory one.  A lot of stuff just didn't work, despite being enabled in the long coding.
willni
« Reply #32 on: January 31, 2017, 01:29:51 pm »
[/quote]
[/quote]
maybe my vw dealer will do it for a decent price
Racoonroll
« Reply #33 on: October 18, 2017, 09:58:07 pm »
Hey guys, this post helped me to fix battery drain problem for my Golf Plus MK5! Already 3 days and no problems, car starts just fine. I have 2012 RCD 310 audio fitted in my 2006 Golf Plus and it kept discharging battery to the point I couldn't start the car. I searched for compatible canbus without luck, plus couldn't find a guy who would cheaply program it for me so I did this fix. My Fuse Box was a bit different than in the original post but I noticed some guys had the same as mine so here's the pictures what I did, hope it helps.  Everything cost me like 40-50 euro cents :)
https://drive.google.com/open?id=0BxzkZl9W_OpUdm92b2I1b3dCdEk
https://drive.google.com/open?id=0BxzkZl9W_OpURWh1OUJYOFpiY2c
https://drive.google.com/open?id=0BxzkZl9W_OpURERxRWI1X1V3QWs
Here's the links for the parts I used in case you want to use exactly the same:
https://www.omedita.lt/lt/puslaidininkiniai-saugikliai/484-saugikliu-lizdailaikikliai-saugikliu-lizdailaikikliai.html
https://www.lemona.lt/?page=item&i_id=24024  (I needed two of these, don't forget to measure the width of 15A fuse contacts, I forgot which width I used)
