Author Topic: Down on power, misfire on cylinder 3  (Read 8513 times)
Offline sub39h
  • -Given: 189
  • -Receive: 84
« on: November 20, 2011, 06:44:05 pm »
Hi guys, some of you may have seen on my Members' rides thread that my car is misbehaving. Went to Awesome yesterday and was only making 133bhp for some reason, and making a terrible screeching sound higher in the rev range.
Anyhow one of the observers at the RR suggested it was a boost leak and that it might be the bung on my BSH True Seal for the DV relocation that may be loose. I went to B&Q to get a jubilee clip and when I looked under the bonnet I had a better look at the bung. It's jutted up right against the brake fluid reservoir and as the engine's moved around it's sliced a hole through the bung!
I took it to Darren today who scanned it - misfire on cyl 3 around 6500rpm, and overboost fault codes. Taped up the bung so it wasn't letting air in, cleared the codes and then booted the crap out of it up to the redline. Screeched again, engine management light flashed, it hesitated and then it was fine. Rescanned and it had a misfire on cyl 3 again, around the 6500rpm mark.
No other symptoms, completely fine when you're pottering about. No misfires or anything.
Car is a 2006/55 A3 2.0T DSG. Engine code AXX, done 45k odd. Only performance mod is a BSH True Seal.
I'll post the error codes later on as I don't have access to an SD card reader, but any ideas what it might be? It's always cyl 3 by the look of it, and always around 6500rpm
Cheers in advance,
S.
« Last Edit: November 20, 2011, 09:59:26 pm by sub39h »
PLANS: Stage 2+
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Down on power, misfire on cylinder 3
« Reply #1 on: November 20, 2011, 06:48:29 pm »
Sorry forgot to mention no overboost fault codes after I booted it
PLANS: Stage 2+
« Reply #2 on: November 20, 2011, 06:53:20 pm »
No missfire at idle?
Cylinder 3 tormented me for weeks. Plugs, Coils, Fuel filter, PCV, nothing.  New injector, Fixed.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #3 on: November 20, 2011, 07:16:42 pm »
is screeching not the sound of the turbo going?
Diesel Daily Hack.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #4 on: November 20, 2011, 07:21:44 pm »
I don't think so because it's not constant. It's fine hits 6500rpm and then starts like a switch
Cheers Mike, I was thinking an injector or the spark plug, but it had a major service in Feb time so spark plugs should have been done. No no misfire at idle, or when driving even 80% or so. Only when you redline it that screech, slight hesitation and flashing warning light
PLANS: Stage 2+
« Reply #5 on: November 20, 2011, 07:25:04 pm »
Hope you get to the bottom of it soon  :happy2:  Its so frustrationg when things like this happen
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #6 on: November 20, 2011, 07:35:42 pm »
I know :-(
PLANS: Stage 2+
Offline keano
  • -Given: 79
« Reply #7 on: November 20, 2011, 08:01:45 pm »
Aren't the Tru Seals and the p-flo's renound for the harmonic screech at high revs?
Try your old intake dude. And also have a butchers at your coilpack on cylinder 3 :)
« Reply #8 on: November 20, 2011, 08:03:16 pm »
Aye, swap the plug and log and the Coilpack and log see if it moves cylinder  :wink:
Offline mortygttdi
  • -Receive: 146
« Reply #9 on: November 20, 2011, 08:45:24 pm »
Bollox forgot to check that, never even crossed my mind although I did think the spark plug possibly not gapped properly??
Here's the scan for you buddy.
Sunday,20,November,2011,17:12:15:16399
VCDS Version: Release 11.11.0
Data version: 20111111
                Address 01: Engine       Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 8P0 907 115 A    HW: 8P0 907 115 A
  Component and/or Version: 2.0l R4/4V TFSI  00 0150
           Software Coding: 010300031C070060
            Work Shop Code: WSC 06314 000 00000
                      VCID: 3065FEE0A3384CE
3 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
               P0300 - 001 -
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 72533 km
                    Time Indication: 0
                    Date: 2011.11.20
                    Time: 16:56:43
             Freeze Frame:
                    RPM: 6445 /min
                    Load: 71.0 %
                    Speed: 86.0 km/h
                    Temperature: 83.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.970 V
000771 - Cylinder 3
               P0303 - 001 - Misfire Detected
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 72533 km
                    Time Indication: 0
                    Date: 2011.11.20
                    Time: 16:56:43
             Freeze Frame:
                    RPM: 6445 /min
                    Load: 71.0 %
                    Speed: 86.0 km/h
                    Temperature: 83.0°C
                    Temperature: 21.0°C
                    Voltage: 13.970 V
004688 - Fuel Level too Low
               P1250 - 008 -
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 72533 km
                    Time Indication: 0
                    Date: 2011.11.20
                    Time: 16:56:44
             Freeze Frame:
                    RPM: 6475 /min
                    Load: 72.1 %
                    Speed: 86.0 km/h
                    Temperature: 83.0°C
                    Temperature: 21.0°C
                    Voltage: 14.097 V
Readiness: 0000 0100
The last I see a lot on the A3 when the fuels low, It doesn't let you clear the codes when the fuels low :confused:
Darren
« Reply #10 on: November 20, 2011, 08:54:17 pm »
Mine from the cylinder 3 issue before the new injector....
               P0300 - 002 - Lower Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 95717 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 05:14:38
             Freeze Frame:
                    RPM: 756 /min
                    Load: 17.6 %
                    Speed: 0.0 km/h
                    Temperature: 84.0°C
                    Temperature: 45.0°C
                    Voltage: 13.716 V
000771 - Cylinder 3: Misfire Detected
               P0303 - 002 - Lower Limit Exceeded
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 95717 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 05:14:38
             Freeze Frame:
                    RPM: 756 /min
                    Load: 17.6 %
                    Speed: 0.0 km/h
                    Temperature: 84.0°C
                    Temperature: 45.0°C
                    Voltage: 13.716 V
Readiness: 0000 0001
« Reply #11 on: November 20, 2011, 09:46:32 pm »
Hmm, did you get your coil packs changed with the recent recall seeing you have an AXX engine?
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #12 on: November 20, 2011, 10:04:34 pm »
cheers for the help so far guys
had the coil packs done under recall about 2 months/2000mi ago so i didn't think it would be that.
i was going to put on the standard air intake and see if there's any difference, but i'm not technically minded enough to be swapping spark plugs. i know it's not hard but if you've read any of my threads lately you'd know i'm not someone to be messing with key components  :rolleye:
on my drive from Yorkshire back to Stoke i noted that when you're trying to hold a speed (i.e. 70mph on the motorway) the speedo needle does wobble up and down a bit (+/- 1 or 2mph i'd say). no jerkiness inside the car, and the rev needle is rock solid
PLANS: Stage 2+
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #13 on: November 21, 2011, 03:39:08 pm »
slightly off topic:
bacillus, i noticed you had okada coil packs. what's the advantage of these?
PLANS: Stage 2+
Offline robdf2
« Reply #14 on: November 21, 2011, 07:39:06 pm »
i like this post
but coils are easy to change as well as plugs , a bit of patience and you will be armed with as much knowledge as the normal VW teccy.
the missfires i had were down to plugs , mine lasted about 8,000 miles if i was lucky.
2008 Chrono yellow Cupra
