Author Topic: P0299 Fault code?  (Read 12667 times)
Offline N13SCB
P0299 Fault code?
« on: November 20, 2011, 07:04:16 pm »
Im just wondering if anyone has had a similar problem to me before I go to a final VW diagnostic specialist on Wednesday.
Since my car had a stage 1 map it has never really ran properly, feels like its gutless. Iv had the car plugged in and p0299 was the code that appeared ( failure to reach circuit boost....or along the lines of that )
Iv asked about this and went to a few garages and iv changed everything that people thought could be related to this. Changed my DV to the piston type, got a new n75 valve, had my MAF checked, changed my oil and got new plugs, and the code is still present?
I then plumbed in a boost gauge and the strange thing was that the car is making 16psi and its making it very quickly with no signs of leakage, spiking etc... But it really doesnt feel like there is any there at all.
Has anyone had a scenario like this before?
Cheers  :happy2: Stu.
Slowly progressing. . .
Re: P0299 Fault code?
« Reply #1 on: November 20, 2011, 08:38:36 pm »
Offline gti darcy
« Reply #2 on: August 29, 2014, 05:27:25 pm »
Did you ever find the problem as I am in the same boat at the min any help would be great
Offline GTI5
« Reply #3 on: August 29, 2014, 05:47:51 pm »
If everything else has been investigated,the turbo may have cracks around the wastegate leaking boost.
It appears to happen on K03 and not K04. Mine was intermittent P0299, as the casting heated this would bring the fault as the cracks expanded.
Run the car on a dyno and inspect the data.
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline gti darcy
« Reply #4 on: August 30, 2014, 04:11:03 pm »
Hi thank for the help took the exhaust of to day to see the actuator rod had snapped so change that and all good but that was one tricky job very tight to work
Offline Shaw
« Reply #5 on: August 30, 2014, 06:25:27 pm »
I love a happy ending :)
'07 Mk5 GTI Manual
Offline gti darcy
« Reply #6 on: August 31, 2014, 02:13:53 am »
Not all happy as I tried to repair the the actuator rod but It has snapped again and tps say the actuator only comes with the turbo dose anyone no where I can get a replacement one thanks
