November 24, 2024, 02:43:20 am
All Things Mk5
Sat Nav and Car Audio
Can I retrofit the mk5 R32 speakers to my Mk5 fsi match?
Topic: Can I retrofit the mk5 R32 speakers to my Mk5 fsi match? (Read 1419 times)
ripmateyy
Always Involved
-Given: 16
-Receive: 18
November 21, 2011, 09:07:00 am »
I know someone selling the 3 way front door speakers from a Mk5 R32. Was wondering is one it could be easily done and two if it would be worth doing?!
Jack
Eddie-NL
Trader - 2014
Just look at my post count
-Given: 0
-Receive: 298
My Ride:
Re: Can I retrofit the mk5 R32 speakers to my Mk5 fsi match?
Reply #1 on:
November 22, 2011, 06:44:00 am »
Hi
I did this for someone not long ago
You will need to change the wiring and add the crossover units to each front door
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
daveangel
Always Involved
-Given: 6
-Receive: 6
Reply #2 on:
November 24, 2011, 07:34:59 pm »
you will ned to remove the outer door skins to change the door wiring loom. its not bad to do though.
ripmateyy
Always Involved
-Given: 16
-Receive: 18
Reply #3 on:
November 27, 2011, 12:51:50 pm »
Cheers guys, he sold them now so can't do it anyway, are they any good or would I be better off buying some focal or
JL 3 ways!
daveangel
Always Involved
-Given: 6
-Receive: 6
Reply #4 on:
November 27, 2011, 01:07:36 pm »
the only thing the factory loom gives you is the crossover and mid cabling. i would say its far easier to rewire the door speakers with the crossover that will comw with whatever you decide to buy. i did what you suggested and now im building a patch cable to interface the rainbow crossovers to the door wiring. i would have neeb easier to go with rainbow first. that and factory speakers are sh*teeeee
All Things Mk5
