Author Topic: Has nyone had this fault code before?  (Read 3112 times)
Offline heavyd
  • -Receive: 29
« on: November 22, 2011, 04:02:13 pm »
Hello folks.
My car just seems to throw one fault after another :confused:
Just wondred if anyone has had this code before, and how they solved it?
I'm getting sick of throwing money at parts lately, so was trying to do some research this time before I go out spending again!
It popped up a couple of times in the last week, I didnt notice anything happen to the car, just the CEL light appeared on the dash again
1 Fault Found:
000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
               P0011 - 004 - No Signal/Communication - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100100
                    Fault Priority: 0
                    Fault Frequency: 4
                    Mileage: 74209 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:17:21
             Freeze Frame:
                    RPM: 1638 /min
                    Load: 35.3 %
                    Speed: 55.0 km/h
                    Temperature: 33.0°C
                    Temperature: 7.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.605 V
Offline mortygttdi
  • -Receive: 146
Re: Has nyone had this fault code before?
« Reply #1 on: November 22, 2011, 05:28:53 pm »
Not come across it before but this is RT take on the fault
16395/P0011/000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
Possible Symptoms
Power Loss
Possible Causes
Camshaft Adjustment Valve 1 (N205) faulty
Fuel Pump Relay (J17) faulty
Mechanical Timing not correct, including Chain and/or Belt timing.
Possible Solutions
Check Camshaft Adjustment Valve 1 (N205)
Check Fuel Pump Relay (J17)
Check Mechanical Timing
Special Notes
When found in Engine: 4.0l W8
Check TPL 2010059(RoW)
Check/Replace Oil Sieve in Timing Case (Camshaft Adjuster)
Also have a look through this
http://highlanderclub.ru/files/manual/04/21j6674h/cip0011.pdf
Offline heavyd
  • -Receive: 29
« Reply #2 on: November 22, 2011, 05:44:44 pm »
Thanks Darren.
Looks like yet another chew on :sad1: :sad1:
Hopefully it was when the fuel line came off the fuel filter as when I convereted the km's back to miles, it works out the error was from sunday, I've known it take a couple of days to throw a MIL before. I wonder if the fuel cuts could have caused it aswell. With a bit of luck the fuel system is all sorted and it wont come back again
