Author Topic: Another 56 plate with rust on it!!  (Read 2727 times)
Offline njdudsbury
« on: November 22, 2011, 10:25:22 pm »
Gave my car the monthly deep clean and noticed some corrosion in the following places.
On both wiper arms around the fixing nut area.
And worse still under the front lip of the bonnet running from the edge up to the rubber stop (drivers side)
Question:-
What is the process?
Do I go down the dealers then they take details and send to VW uk for assessment?
Don't expect this on a six year old car!
Pretty cheesed off as I have kept it mint from new and its only got 38k on the clock
Offline Stevenebm
Re: Another 56 plate with rust on it!!
« Reply #1 on: November 22, 2011, 11:49:33 pm »
yeh mate head to your local dealer bodyshop i think.you will have a strong case having it from new.i found a bit on mines but since i havent had from new im going to get it sorted myself.i would say these cars are worse than fords having owned fords for the past 8 years.dissapointed as vw have a good rep.
Offline njdudsbury
« Reply #2 on: November 23, 2011, 08:58:46 pm »
Got it booked in tomorrow @ the dealer body shop to take photos and details for VW uk to assess
Fingers crossed!
Anybody had any work done @ the bodyshop @ VW Derby?
Offline Fletch..gti
« Reply #3 on: November 24, 2011, 02:26:19 pm »
I have had paint at derby ( parkway ) and am a little picky to , but the job they did was spot on .
You should be fine
Offline AwesomeHassan
« Reply #4 on: November 24, 2011, 03:12:26 pm »
Very annoying to hear a car starting to rust so early.
I hope you get it sorted.
Offline OEM+ DUB
« Reply #5 on: November 24, 2011, 04:09:09 pm »
You should be fine
+1.  I've had lots of work done by Parkway Paint and Body and they have always been spot on for me too.  :happy2:
OEM+ 2005 GTI DSG (high factory standard spec and upgraded with S3 alloy hubs, S3 alloy wishbones, Bilstein B8s and VWR springs by my own hands) owned since 2008 and still loving it!
Offline neil86
« Reply #6 on: November 24, 2011, 06:04:48 pm »
I have a 57 plate and found rust on under side of my bonnet also, annoyed to say the least i cant believe this so called build qaulity.
Offline njdudsbury
« Reply #7 on: November 25, 2011, 12:30:38 pm »
Took it to Parkway Derby and the chap didn't have a problem with what i showed him.
He is going to recommend that the bonnet is replaced as the problem is on the inside of the outer skin which you cant physically get to, to repair.
He also did say the VW are the worst warrenty people to deal with having work at other car dealers in the past. Every warranty job that comes in is a battle!
See what happens.
Offline Mk5 GTian
  • -Receive: 37
« Reply #8 on: November 28, 2011, 06:07:03 pm »
I took mine into Colbournes Guildford today, as it had a couple of spots and loose paint on the o/s/r wheelarch (a common problem apparently). They checked it out, and refused my claim, as it had already been repaired in this area, and badly. Still waiting for their quote.  They said it didn't matter that I was 3rd owner though, it's the car that is covered for 12 years.
Got a price of 240 from Bells Accident repair in Guildford, which included sorting out 3 other scratches on the same wing.
Offline njdudsbury
« Reply #9 on: January 05, 2012, 08:45:22 pm »
Went in to remind them yesterday and VW warranty have chucked out a new bonnet and said it its just a rub down and paint job based on the images provided. How can you rub it down and then paint over the rust that is coming from the inside of the bonnet skin!! Guy at VW fully backs me and said we should remove some sealant and get some better photo's to show the rust coming from the inside. I,m a bit concerned about doing that incase it all gets chucked out (which I dont think will happen) and leave me with a rusty car with the sealant cut away?
Anybody been in a similar situation??
Offline njdudsbury
« Reply #10 on: January 06, 2012, 11:20:42 pm »
Well been down the body shop again today. They took some sealant off and there is rust all the way along the seam between to inner ans outer skins. Look like its been there ages and only just getting through the paint after 5 years. Dont expect to pay 18k from 2 months old and have rust on it.
Anybody else got rust under their bonnet? Have a look as I never realised until I gave it a good clean under there.
Offline neil86
« Reply #11 on: January 07, 2012, 08:19:00 am »
Mines bubbling paint like moisture has got in and started to attack. Dont think full on rust yet, great qaulity these!!!!
Offline njdudsbury
« Reply #12 on: January 07, 2012, 08:36:11 pm »
That's how mine is there will be loads of rust underneath, I was shocked to see how much when we cut the sealant back.
The paint looks like its got tiny water bubbles as you say. I will try and get a picture in the morning and post it.
Offline njdudsbury
RESULT FROM DEALER:- Another 56 plate with rust on it!!
« Reply #13 on: January 10, 2012, 12:27:37 pm »
Just had another call from the body shop to say VW uk have agreed to replace the complete bonnet.
Pleased about that didn't want to have it painted to see the rust come back in a few years.
Might have it in for a cam belt and pump at the same time
Whats the going rate for that at the minute?
