Author Topic: Dv colour spring  (Read 2065 times)
keendean
Dv colour spring
« on: November 24, 2011, 11:41:01 am »
Hi,
What colour spring?
« Last Edit: June 12, 2012, 04:15:47 pm by keendean »
Re: Stage 2 + Gti and Forge Dv colour spring
« Reply #1 on: November 24, 2011, 11:59:04 am »
Hi,
What colour spring should my forge dv be using on a Stage 2+ Gti? I think green, but what are people using?
On WOT it seems as if its very noisey, like a high pitched squeel, I'm assuming the DV is playing silly buggers.
I'm putting it on the rollers soon at Jabba, to see if all is well :)
Ring Forge and ask for John and he will know, off the top of my head I changed mine for a yellow one but could be mistaken
« Reply #2 on: November 24, 2011, 01:46:04 pm »
Yellow spring for stage 2+...   :happy2:
Offline Little_Dave
« Reply #3 on: November 24, 2011, 02:46:27 pm »
Not sure what spring my one has in it but was fitted back when i had stage 1 put on the car so i'm guessing not the right one now :confused: what difference does it make running the wrong spring? Did it make a big difference if any of you changed it over?
Dave
Offline AwesomeHassan
« Reply #4 on: November 24, 2011, 03:20:10 pm »
It should be a yellow spring on remapped vehicle and green spring on a standard vehicle.
Basically the yellow spring is a stiffer spring. It keeps the valve shut when on boost.
If you have a green spring on a mapped vehicle, the spring can be weak and the valve could open on boost, thus loosing boost
I hope that helps
« Reply #5 on: November 24, 2011, 04:31:20 pm »
At high revs and boost, there is a loud hissing sound, sounds similar to the DV when letting off, so only presuming since going from Stage I to II, the original green sprinsg is still in it. As said, it's going to Jabba soon for a power run and check over, fingers crossed all is OK :)
Hissing maybe one of the vacuum lines to the dv split. I have suffered this before.
Offline Little_Dave
« Reply #6 on: November 24, 2011, 07:57:39 pm »
Is it a yellow spring regardless of how much the car has been tuned? Got mine fitted with a stage 1 map so am i right in guessing it should already be a yellow one?
Dave
« Reply #7 on: November 24, 2011, 08:07:45 pm »
Dave
Only way to tell 100% is to look at the spring as iirc the dv unit now ships with both green and yellow springs.
Offline Little_Dave
« Reply #8 on: November 24, 2011, 08:14:14 pm »
I'll get them to double check for me when i get my new brakes fitted on monday  :happy2:
Dave
