Author Topic: Autolights Stopped Working?  (Read 1289 times)
Offline Betty02
    • iBett
« on: November 25, 2011, 08:54:26 am »
Went out last night, pulled up, switched all engine off etc, head unit and everything really, pulled keys out of ignition so lights came on then put them back in. Anyway sat there for 30 mins max, turned car on and my auto lights didn't come on? Switched them on and all lights were working fine, no bulb out errors etc, so switched car back off, switched lights back to auto, locked car, unlocked it and tried again and it was still the same.
Anyway drove hope with them on, go home, stuck them back onto auto and nothing, locked car went to bed etc, got up this morning and still the same? They have never let me down before could it be a simple fuse? All auto wipers are still working though?
ADMIN NOTICE: Please do not use the site for advertising!
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Autolights Stopped Working?
« Reply #1 on: November 25, 2011, 08:56:55 am »
Have you got access to VCDS to see if there are any errors as it could be a duff sensor (but that would surprise me)
Offline Betty02
    • iBett
« Reply #2 on: November 25, 2011, 08:59:28 am »
Nope need to get a cheap VCDS cable if I can, always stuff I could bloody check!Any other suggestions?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #3 on: November 25, 2011, 09:32:48 am »
I don't think it would be a fuse but you could check it (you'd have to look in the manual as to which it is)
Does your coming home/leaving home function work?
Oh and don't get a cheapo VCDS cable. Save and get a proper one.
Offline Betty02
    • iBett
« Reply #4 on: November 25, 2011, 04:02:03 pm »
Where's the sensor? Going to try clean it!
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #5 on: November 25, 2011, 04:08:49 pm »
Usually where the rear view mirror meets the glass. If you look at that portion of the screen on the outside you will have a black square with the sensors viewable inside that.
It would only be the screen part that was dirty not the sensor unless you have had the Screen replaced.
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #6 on: November 25, 2011, 04:41:30 pm »
Do you have highline? You can check your convenience settings in there. If not, I'd start with the sensor & work back. Does the headlight selector switch illuminate the auto lights icon when set?
Offline Flashpilot
« Reply #7 on: November 25, 2011, 04:58:18 pm »
 Bugger....I hate people giving me help/advice one day then having grief themselves the next!!
Dunno if it's any help, but I nada similar fault with a BMW of mine a while back and the settings had reset and so it wouldn't switch the lights on....even in auto (this is what I was told by the guy that sorted it anyway???.). Maybe look at the convenience settings as suggested above?
Offline Betty02
    • iBett
« Reply #8 on: November 29, 2011, 10:05:55 am »
Hi chaps, had a look for the sensor am I being stupid but I couldn't find anything :S
I also only have a midline dash too so the settings are out of the question :(
All the lights on the switch light up fine etc so it's just not coming on?
Offline Betty02
    • iBett
« Reply #9 on: November 29, 2011, 10:10:44 am »
Stupid me, read the sensor are wrong! Will go give it a clean now! Probably too light mind you but no doubt when I finish work it will be dark!
Offline sirwiggy
  • Here For A Good Time Not A Long Time
« Reply #10 on: December 01, 2011, 06:49:50 am »
Hello mate, I'm having the same problem as you with no idea what the fault is, but then left my car at my boss house at the weekend and went to pick it up tuesday and battery was dead flat. My mate seems to think that battery could be at fault as it won't hold it's charge going to change it.
