Author Topic: FWD - Power to weight V's outright power which is best?  (Read 4262 times)
« on: November 26, 2011, 11:35:29 am »
I've wrecked my brain thinking about this and am still conflicted. The pro's and cons for each are mind boggling. So a problem shared is a problem halved as they say :laugh:
So, what do you all reckon, for FWD - which is best, big power?, big bhp/ton?, a balance of the two? Which is best for track?, which is best for road? which is best overall?
My mind settles on lightweight and a balance of power that suits the car, but what is the best power to weight for a FWD?
Mad power and lightweight can ruin a car, but then too much weight and not enough power is probably dire too!
Some MKV's on here have over 250bhp/ton, is it worth going beyond this or not?
Discuss and help sooth the mind of a raddled and rattled old modifier  :driver:
Re: FWD - Power to weight V's outright power which is best?
« Reply #1 on: November 26, 2011, 11:42:56 am »
you ever seen a clio 172 phase 1 stripped out and plexi glass fitted? a few went to oulton with the mk5 boys a few months ago and every one was how fast the little bugger was and not much could keep up with it as they all thought it had a turbo fitted but the guy opened the bonnet and it was bog o stock  :driver: to say it upset em all  :signLOL: was funny as it proved light weight and balance works perfectly.
« Reply #2 on: November 26, 2011, 11:50:42 am »
But would it have been even better with a turbo and more power?
« Reply #3 on: November 26, 2011, 12:06:16 pm »
faster on the straights yeah but it might upset the balance a little i think its like the xbow i drove everything about it was so well balanced as a whole package and with the map and a milltek it was better but the balance was a little off but don't get me wrong bloody fast  :smiley: .Its all about the balance as you could have 600bhp but still get your arse handed to you by a 200bhp light weight car as it will be able to abuse its hp but the high power just can't put it all down hence why the little clio trophy was able to pretty much kick a lot of bigger cars arses in evo trials.
« Reply #4 on: November 26, 2011, 12:12:11 pm »
you having the diff done?
Offline RobH
  • Revo stg 2+
« Reply #5 on: November 26, 2011, 12:20:53 pm »
Least weight as possible BUT the chassis has to be able to cope with the power also the delivery of the power would be important aswell. Best doent have to mean quickest.
Also power to weight and outright power are kinda the same thing if you have huge power you going to have a good hp per tonne.
« Last Edit: November 26, 2011, 12:24:27 pm by RobH »
Offline PDT
  • -Receive: 142
« Reply #6 on: November 26, 2011, 12:51:03 pm »
My choice is a high revving N/a  in a lightweight shell. One of my old cars weighed 720kg, had a race spec 1670cc making 214hp and 155 ft/lb making peak power at 9500rpm. Not much could keep with it. No wheelspin issues etc... Not an ideal road car due to noise and poly windows etc...
I have been in a fair few lightweight turbo cars with 300+hp and they just struggle to get traction, even with a diff. but they behave OK on the road and the extra power means you dont need to compromise so much on losing the comfort and daily driver aspect to get the power to weight correct.
Offline PDT
  • -Receive: 142
« Reply #7 on: November 26, 2011, 12:55:34 pm »
lightweight with 214hp 0-70mph
&list=UL
the noise was addictive
« Reply #8 on: November 26, 2011, 12:58:01 pm »
Need you ask  :signLOL:
Offline Dan648v
  • -Given: 28
« Reply #9 on: November 26, 2011, 01:27:46 pm »
&list=UL
AHHH the sweet sound of throttle bodies!! I had some on a 106 rallye and it was addictive to say the least at 170bhp and 750kgs!
Offline Janner_Sy
  • -Receive: 113
« Reply #10 on: November 26, 2011, 02:25:32 pm »
I remember when you initially got the car, and you said that 250hp would be the sweet spot........It took you all of 1-2 months before you started hunting the big power :grin: and your pulling me in with you  :scared:
I personally agree with your initial thoughts tbh, and believe that any more than 250hp on these platforms will just become a nightmare or waste of time.
When i mentioned to VWRacing that i was surprised to have torque steer with such small power, they agreed saying they couldn't believe how much blades had with only a stage 1 map.  So i cant imagine what it would act like with another 60-70Hp.  You would spend most of your time fighting the torque steer instead of trying to corner or accelerate smoothly.  To much more power and i thik we will end up surpassing or ruining the capabilities of this chassis.
If your chasing 1/4 mile times then yeah big power, low weight.  But these chassis/engine combos are great for twisty track work, and dont need huge power to pull it off, unlike alot of heavier machinery
Ive been doing a lot of inquiries about this.  Quaife, Peloquin and wavetrac have said that unless they can get hold of a cheap DSG7 gearbox they are not that bothered about developing it.  APR Australia have been developing one alongside a german company, however that is a plate differential and not a ATB diff.
Main issues with that are that plate differentials need servicing as the plates wear down.  They are not a fit and forget item, so whilst plate diffs are regarded as being superior to ATB diffs, is that a good option if its not going to last very long??
« Last Edit: November 26, 2011, 02:28:44 pm by Janner_Sy »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=olk3ikmlflfkg3fmous7ua4e3j&/topic,19740.0.html
« Reply #11 on: November 26, 2011, 03:07:47 pm »
If I were in a position to set my car up for track I would strip in out to reduce its weight first, before considering more power.
~1000kg and ~300 bhp should be enough power for anyone.
Offline jhtrophy
  • Oh no it's a diesel
« Reply #12 on: November 26, 2011, 03:30:47 pm »
Meg trophy? Did I just say that :signLOL: I have to say for track stuff, 200 bhp per tonne is plenty in a fwd, particularly on a short circuit, as much as I love the stage 2 ed 30 I'm not convinced that the power is necessary, I think your car John would have done similar times on track without the engine work tbh.
« Reply #13 on: November 26, 2011, 05:07:22 pm »
Hmm, you maybe right. I think that maybe a switchable map for me on a hybrid turbo and water/meth would make the bigger bhp, but could be switched DOWN for trackwork and UP for 1/4 miles to give me the best of both worlds.
I reckon the Polo can get to a sub 1100kg without stripping the interior at all. Maybe power can get up to 280-290bhp with w/m = 255-260bhp/ton or leave as it is for trackwork at 210bhp/ton and with a diff should be interesting.
You see my quandry! as the car stands now it is very fast around the twisty stuff, but not so fast on the straights, however if I up the power then the balance swaps and the straights become faster and then it is more about timing turns between power off/brake/turn/power on, rather than piling into a corner with good balance and letting rip on the way through. :evilgrin:
N/A is great for reducing wheelspin as the torque is lower, but then the same questions can be aimed at torque - big lbft or smaller lbft and lighter car?
Offline tony_danza
  • -Receive: 112
« Reply #14 on: November 26, 2011, 10:44:12 pm »
I ran various maps on the SPS for different things, track version was low torque and 280BHP in the MK5, I found this to be the best balance - for every few tenths gained by being faster into a bend, you're losing them not being able to get back out. Finding speed through a corner is key, and that's nothing to do with power.
The Chapman theory. Always. Adding lightness is generally free and massively effective. Chucking more power at a car to make it faster around a track is the wrong way to go.
The single best thing Team Bora did with their track car was get the MKI TT wishbones/uprights with Defcon inserts/solid bushes. I believe you have the same basic chassis as a MKIV?? Going on from there, raid the VW Motorsport catalogue for the triangulated rear beam, or have Statlers fab one.
Thinking on, there may be a watered down Group N version of the Polo R rally car? Given you can buy all the race car bits from Renault for the Clio, you may be able to snaffle stuff off the Ibiza/Fabia/Polo race cars??
« Last Edit: November 26, 2011, 10:48:37 pm by tony_danza »
Sideways yo!
