Author Topic: Mapping Issues - Superchips - Graphs Added  (Read 9922 times)
Offline Janner_Sy
  • -Receive: 113
Re: Mapping Issues - Superchips
« Reply #15 on: November 29, 2011, 12:16:55 am »
stage 2+ solved alot of the issues on mine, but it was by no means smooth.  It was also slower than a stage 2 Shark vRS without the fuel pump or intake
Offline liver
« Reply #16 on: November 29, 2011, 08:16:20 am »
i agree there customer services and after care is second to none.
im having some problems with my work emails i think there will be an email waiting once i get them up and working again
Offline liver
« Reply #17 on: November 29, 2011, 09:04:16 am »
Hi Mark
I’m sorry that you’re having issues, I have checked the database and can see that you have been running this current map since May, I’m sure that you would have noticed back when you first installed the updated map if this issue was occurring, please log the air flow reading as this type of symptom is caused by a faulty airflow sensor, I also notice that you have a induction kit fitted, and these can cause the airflow meter get contaminated. If the airflow meter is faulty these do not flag a fault in the ECU, this is because the deteriorate over time.
Regards
Dave
Offline Janner_Sy
  • -Receive: 113
« Reply #18 on: November 29, 2011, 09:18:01 am »
Tbh I never noticed mine was bad until I drove someone else.
Offline liver
« Reply #19 on: November 29, 2011, 09:19:31 am »
Morning,
Sorry I was having trouble with my emails and could not receive any so I have only just received your message this morning, I will log the air flow reading tonight, however I am not convinced that this will indicate any problems. The car is a daily driver to due to this very rarely goes above 4k revs with my commute hence the reason this has not flagged up sooner other than data logging and a rolling road session. Do the logs indicate any problems?
Regards,
Offline liver
« Reply #20 on: November 29, 2011, 01:41:10 pm »
ive done to some graphs to compare actual and specified boost and rail pressure for the three logs i did, ive got them in pdf and word but not sure hows best to put them up
any help is greatly appreciated
« Reply #21 on: November 29, 2011, 02:07:50 pm »
You could use the add PDF option or take a screenshot of them while open and add as a picture.
Offline liver
« Reply #22 on: November 29, 2011, 02:20:40 pm »
« Reply #23 on: November 29, 2011, 03:35:05 pm »
Nice rail pressure.  :surprised:
What's up with the revs scale?
Offline liver
« Reply #24 on: November 29, 2011, 03:41:11 pm »
i know, its terrible isnt it,
what do you think could be causing this? I can send my logs to anyone if they are good at understanding them, i havnt got a clue to be honest, have sent and asked bluefin to inspect but they havnt got back to me with regards to the logs.
not sure on the scale either
Offline liver
« Reply #25 on: November 29, 2011, 04:01:24 pm »
the graph, missing the last 261bhp run but you get the idea of the problems
Offline liver
Re: Mapping Issues - Superchips - Graphs Added
« Reply #26 on: November 29, 2011, 07:59:33 pm »
what else would be good to log with air flow to help get somewhere with bluefin?
Offline liver
« Reply #27 on: November 29, 2011, 10:37:00 pm »
my logs
Log1, run 1
Log1, run 2
Log1, run 3
Log 2, run 1
Log 2, run 2
If anyone can help me and point me in the right direction with any problems they may see it would be greatly appreciated.
Im just trying to build a strong enough case to show that the problem is not with my car but actually with the map
but im not very good with actually reading the info i have
cheers
« Last Edit: November 29, 2011, 10:48:19 pm by liver »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=bp5i7vmlj9k9o5p69p4dsvhqvm&/topic,19740.0.html
« Reply #28 on: November 29, 2011, 10:56:35 pm »
OK.... easy way to prove that its the map.
Remove the Map with your Blufin box. Re-log the MAF airflow... and repost the values. Its easy to see that your current MAF figures are taking a big hit at 4500rpm.
Rich
« Reply #29 on: November 29, 2011, 10:58:35 pm »
Looking at your rail pressure plots, when was the last time you checked you cam follower?
