Author Topic: Mapping Issues - Superchips - Graphs Added  (Read 9921 times)
Offline liver
Re: Mapping Issues - Superchips - Graphs Added
« Reply #30 on: November 29, 2011, 11:26:14 pm »
I will remove the bluefin tomorrow and relog, cheers thats a great idea
The cam follower was replaced around a month ago
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=egd8q16cbphjuv9d6vedkf9jsl&/topic,19740.0.html
« Reply #31 on: November 29, 2011, 11:28:03 pm »
No probs... fingers crossed that you get a normal MAF log, and its not your car. (i suspect your car is absolutely fine)
Offline liver
« Reply #32 on: November 29, 2011, 11:40:35 pm »
Will i need to log the car with both the different groups of measuring blocks or will one notify better than the other?
« Reply #33 on: November 29, 2011, 11:41:58 pm »
Just log the MAF (Intake Air g/s)
Offline Janner_Sy
  • -Receive: 113
« Reply #34 on: November 29, 2011, 11:47:19 pm »
The biggest issue on mine was with the fueling, with similar logs to your rail pressure.  Make sure you log fuel rail pressures on stock settings
« Reply #35 on: November 29, 2011, 11:49:40 pm »
^^ good idea.  :happy2:
Offline liver
« Reply #36 on: November 30, 2011, 08:30:01 am »
Thats fine i shall try and get the car back to standard form at work today and then log the car tonight
i will log the air flow, fuel rail pressure and boost with the revs to give a good indication of the differences
fingers crossed its the software.
I have forwarded on the second set of logs to Dave this morning and hopefully today he'll get back to me
Offline liver
« Reply #37 on: November 30, 2011, 09:02:25 am »
another reply
Morning Mark
On the first log that you have sent me we have noticed that you Group 230 actual rail pressure falls at 3280 rpm, the specified remains at 109.4 BAR,  this is causing the ECU to lower the boost pressures and power figures for safety reasons.
This will probably not happen when you return the car so the factory map as the fuel demand is not as high, but the problem is in the engine not on the map.
Regards
Dave
I had noticed this looking at the graphs that it was the actual that was struggling and not the specified which im guessing is what the map asks for.
Dave thinks the issue will either be with the pump itself or the lobe on the cam shaft wearing, if you have an early cam shaft and an aftermarket pump, the cam shaft lobe will wear. Would people agree with this.
The pump is a standard pump with a new cam follower a month ago so can't see this been a problem
« Last Edit: November 30, 2011, 09:19:40 am by liver »
« Reply #38 on: November 30, 2011, 11:33:47 am »
Did you ever look at your low fuel pressure sensor that's on the hpfp as the early versions are known to fail...
Offline liver
« Reply #39 on: November 30, 2011, 12:57:24 pm »
no i didnt, i just changed the cam follower, how would i go about checking this?
Offline liver
« Reply #40 on: November 30, 2011, 10:42:00 pm »
car has the standard map on and everything runs fine and meets all requirements as seen below,
i just dont understand why it is fuel cutting with the stage 2 software on, when the specified rail pressure stages constant but the actual pressure drops hmmmm
« Reply #41 on: November 30, 2011, 10:47:26 pm »
^^ MAF figures are bang on!
Offline liver
« Reply #42 on: November 30, 2011, 10:50:43 pm »
I know, maf figures, rail pressure figures and boost are all spot on
Dave at bluefin said they would be he claimed this because the fuel pump isnt requesting as much fuel or under as much pressure
I really am lost as to wether its the car or the software
Offline PDT
  • -Receive: 142
« Reply #43 on: November 30, 2011, 11:52:19 pm »
Surely its requesting 110 bar stock and on stg2?
But its only getting fuel cuts on when using stg2 software?
Offline liver
« Reply #44 on: December 01, 2011, 08:27:32 am »
yeah very true PDT i hadnt noticed that on both standard and on the stage two map the specified rail pressure is the same at 109.4
so surely its got to be the software thats at fault and not the car
would you suggest looking at the logs etc that it is the software at fault and not the car PDT?
« Last Edit: December 01, 2011, 08:37:03 am by liver »
