Author Topic: tyre question  (Read 3279 times)
Offline gti yorks
tyre question
« on: November 26, 2011, 12:33:42 pm »
i have bought myself some michelin ps3 of ebay and they turned up today, my question is, can i put new tyres on the front or should i move my rear ones to the front??? i have conti 3's on the rear which are not that old, they have about 6-7m on them.
i did see the answer to my question on here a few weeks ago, but cant find it now, sorry  :ashamed: :ashamed:
Offline alexperkins
  • -Receive: 99
Re: tyre question
« Reply #1 on: November 26, 2011, 12:36:01 pm »
Rears last a lot longer compared to fronts so the decision really comes down to you
Offline gti yorks
Re: tyre question
« Reply #2 on: November 26, 2011, 12:40:10 pm »
yeah but i thought i read somewhere that its safer to have have tyres with the most tread on the rear, maybe i just dreamt it and am being a bit stupid :grin: :grin:
Offline alexperkins
  • -Receive: 99
Re: tyre question
« Reply #3 on: November 26, 2011, 12:40:53 pm »
Well its better to have tyres with tread than no tread, but all tyres wear down over time!
Offline gti yorks
Re: tyre question
« Reply #4 on: November 26, 2011, 12:45:23 pm »
i never knew that, thanks for the info :rolleye:
Offline alexperkins
  • -Receive: 99
Re: tyre question
« Reply #5 on: November 26, 2011, 12:46:18 pm »
 :signLOL: no problem  :happy2:
FYI i swapped my fronts and rears 6 months ago and have had no problems
Offline Tamiyoman
  • -Receive: 39
Re: tyre question
« Reply #6 on: November 26, 2011, 12:47:09 pm »
I wold say better to have Tyres with most tread on the front driven wheels, especially with winter coming and with standing water they hit puddles 1st.
I just had my new tyres on front and left the rears as they were, they also have 6mm on rears although are cheapo tyres on rear, once they wear out a bit more i will put some Toyo T1R on the rear to match the fronts, can't go wrong with T1R, been using them for 5 years.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: tyre question
« Reply #7 on: November 26, 2011, 01:18:11 pm »
........as above but why didn't you get the same brand as the rears & match them up?. I run the same brand all round.
Offline gti yorks
Re: tyre question
« Reply #8 on: November 26, 2011, 03:45:13 pm »
i like michelin pilot sport tyres, had them on my previous car and they performed well, but the continental tyres i have are also good, just personal preference really. i plan on replacing the other 2 with michelin ps3's when they are worn out
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: tyre question
« Reply #9 on: November 26, 2011, 03:50:08 pm »
I know what you're thinking re your original question. Conventional wisdom says most tread on the front. However I've recently read in a couple of places the idea that the tyres with most tread should be on the rear. I recall it was with regard to braking stability, particularly in the wet.
Given that your Contis have 5-6mm and a new tyre these days has a max of 8mm, I'd not expect much difference whichever were on the front. I'd probably stick the Contis on the front to wear them out first & then replace them with PS3s  :happy2:
Offline gti yorks
Re: tyre question
« Reply #10 on: November 26, 2011, 04:06:16 pm »
thankyou LouCyffer, i thought i was goin mad for a minute, i knew i had read something like that somewhere. :happy2:  :drinking:
i have been out and had the michelins fitted and have swapped my contis over to the front, the contis have got just over 6m on them.
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: tyre question
« Reply #11 on: November 26, 2011, 04:29:23 pm »
You're welcome, buddy. My mate works at a national tyre fitting chain, & he says most tread should go to the rear. :happy2:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: tyre question
« Reply #12 on: November 26, 2011, 04:44:01 pm »
They say put newer tyres on rear as the thinking is better to have under steer than over steer, but I doubt you would notice much difference with relatively new tyres...
Diesel Daily Hack.
Offline AdeMcG
Re: tyre question
« Reply #13 on: November 26, 2011, 04:58:41 pm »
+1
On a Front Wheel Drive car, the relatively new advice was to put the new tyres on the rear and shift your old tyres to the front.
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: tyre question
« Reply #14 on: November 26, 2011, 05:43:52 pm »
The argument for more tread on the front as said is that understeer is easier to control than oversteer (rear overtaking you as you go round a corner).  Which is perfectly valid and logical.
I know my driving style & the cars limits and choose to put the best tread on the front as the front does all the accelerating, steering and the lions share of the braking.  On a RWD car I think the best tread on the back is a more persuasive argument.
As a back up, a car with ESP will be able to compensate to some extent should the unfortunate happen.
Other opinions will differ  :happy2:
Sepang Blue S4 BE Avant
