Author Topic: tyre question  (Read 3281 times)
Offline alackofspeed
  • -Receive: 24
Re: tyre question
« Reply #15 on: November 26, 2011, 06:46:13 pm »
Tread depth is only one factor. As tyres age and suffer performance degredation irrespective of tread depth, thus if you have 2 tyres of the same type and tread depth but one is 1 year newer, the newer tyre will have better adhesion.
Best bet with the modern ESP systems seems to be to rotate the tyres to wear out at the same time, and not mix and match tread / age / manufacturer - my car's ESP was a complete pain in the butt when for a month or so I had different tyres front to rear.
I'd stick the new tyres on the rear.
Offline m4t_lee
Re: tyre question
« Reply #16 on: November 26, 2011, 09:07:50 pm »
I've always put the new tyres on the rear, keeps them fresh by rotating them and I'd rather try and correct understeer than get the backend step out on me due to lack of grip.
06 Shadow Blue GTI
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Re: tyre question
« Reply #17 on: November 26, 2011, 10:02:41 pm »
 :happy2: :happy2:
no good idea
"You get what you pay for."
Offline vRS_Pagey
  • -Receive: 59
Re: tyre question
« Reply #18 on: November 27, 2011, 09:26:55 pm »
This was done to death recently, there is a video showing the benefits of having newer tread on the rear.  Personally, that's what I do.  :wink:
« Last Edit: November 27, 2011, 09:33:05 pm by vRS_Pagey »
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
Re: tyre question
« Reply #19 on: November 27, 2011, 10:39:00 pm »
Best to have similar good tyres both front and rear.
The only way to achieve this is to fit the better pair to front
where you have more wear on a FWD.
On a FWD I would NEVER fit the better tyres to the rear.  :wink:
Offline sundance
Re: tyre question
« Reply #20 on: November 28, 2011, 12:24:29 pm »
Given that your Contis have 5-6mm and a new tyre these days has a max of 8mm, I'd not expect much difference whichever were on the front. I'd probably stick the Contis on the front to wear them out first & then replace them with PS3s  :happy2:
Exactly what I have done!  :happy2:  I have moved the Bridgestone Potenza S02A to the front of the car and put a new set of PS3s on the back.  As soon as the Potenza's wear out, I'll replace with PS3 and have an all-Michelin setup  :driver:
Offline vRS_Pagey
  • -Receive: 59
Re: tyre question
« Reply #21 on: November 28, 2011, 01:24:57 pm »
I thought the video made it clear what the best set up is tbh, but each to their own.
Offline sundance
Re: tyre question
« Reply #22 on: November 28, 2011, 04:27:29 pm »
I should add in my case the Bridgestones (which have been relocated to the front) have 5mm  -  so plenty of tread.  8mm on the back with the PS3s.  As soon as the Bridgeys hit 3mm they will be promptly disposed of ;)
Offline higher1
Re: tyre question
« Reply #23 on: November 28, 2011, 04:47:36 pm »
+1
Ah-exclusive custom ultra low H&R Coilovers 110mm, ITG induction kit, 18" super RS's, USA rear bumper, USA front grille with smooth number plate surround,recaro bucket seats. now sold !
mk1 golf 1.8 20v turbo
Offline Mk5 GTian
  • -Receive: 37
Re: tyre question
« Reply #24 on: November 28, 2011, 05:49:52 pm »
I've just put new Pirelli P Zero Rosso's on front, and kept old ones with less grip on the back. It's a front wheel drive, so I reckon grip on the front is more important.
