Author Topic: R32 calipers vs Porsche 4 pots  (Read 4869 times)
Offline vagmaster
« on: November 27, 2011, 09:11:20 pm »
Hi fellow fanatics...
Can anyone help me on sizes between these two brake calipers please. Which one is bigger in measurement.
Currently running R32 set up front & rear, but after a 4 pot caliper since car is mapped to 330bhp now.
I like the look of the Porsche 4 pot with the Porsche sign etc, but if it isn't bigger in size then it is pointless as the R32's are doing the job good enough.  :driver:
Vagmaster
Re: R32 calipers vs Porsche 4 pots
« Reply #1 on: November 27, 2011, 09:14:54 pm »
The discs are smaller 312mm.   I have gone from the Cupra 345mm setup and must say they Porsche setup performs great.
I also benifited from the car feeling more agile as loads of unsprung weight was saved  :smiley:
« Reply #2 on: November 27, 2011, 09:16:34 pm »
Just realised you was asking about the big Cayenne calipers before was you not?
My above post refers to the NQS BBK (Brembo Porsche 4 pots)
Offline vagmaster
« Reply #3 on: November 27, 2011, 09:35:21 pm »
Thanks mike,
So are you saying to put back on the ed30 discs and porsche will go straight on and car will also feel lighter etc. I suppose the R32's are heavy.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #4 on: November 27, 2011, 09:42:04 pm »
I found the 4 pot porkers where better than the R32's when running with some better pads and j-hooked disks.
As mike says the weight also makes a positive difference to the feel of the car  :happy2:
Offline vagmaster
« Reply #5 on: November 27, 2011, 09:43:15 pm »
Thank guys...
« Reply #6 on: November 27, 2011, 09:43:47 pm »
I'm really looking forward to fitting my pagid blues, Jhooks and ate racing fluid !
Offline vRSAlex
  • -Receive: 253
« Reply #7 on: November 27, 2011, 10:07:49 pm »
Or how about the FBBK (fairly big brake kit(I made that up BTW)) which is the 345mm discs with either the db9 or r8 rear caliper?  Dave does brackets.
R8 has the better piston size for the master cylinder and the db9 really needs the master cylinder upgrade.  It's hard to find the calipers though.
Follow AKS tuning on Facebook
Offline Phil Miller
  • -Given: 86
« Reply #8 on: November 27, 2011, 10:36:25 pm »
sorry if i sound silly but do the porker calipers bolt straight on to the hub and are the GTI 312mm discs able to be used? also do the standard golf brake hoses fit without having to change them?
« Reply #9 on: November 27, 2011, 10:40:45 pm »
Not sure about hoses as HEL Hoses came with my kit but a fitting kit is required and available from DaveB1970.
Have you read the NQS BBK with install pics thread?  :happy2:
Offline Phil Miller
  • -Given: 86
« Reply #10 on: November 27, 2011, 10:57:35 pm »
i havent but i will  :happy2: what sort of price is the fitting kit?
« Reply #11 on: November 27, 2011, 11:00:00 pm »
Around 2 - 250 I believe.  :happy2:
There are lots of NQSbbk threads but this is the main one;
http://www.mk5golfgti.co.uk/forum/index.php/topic,13985.0.html
Offline dan_the_v8man
« Reply #12 on: November 29, 2011, 03:28:12 pm »
Have you got a part number for the Porsche calipers your thinking about fitting?
Offline vagmaster
« Reply #13 on: November 29, 2011, 04:34:38 pm »
No but I could do with the part numbers of all the porkers that will fit.
Still indesicive as the R32 brakes seem fine as it's a project for the missus not me.
