Author Topic: Zaino Winter Prep / 6 month application - Leon FR  (Read 1994 times)
Offline n_d_fox
    • OCD.etail - Facebook Page
« on: November 28, 2011, 03:33:25 pm »
Completed this detail on my own car at the end of October. New to this forum so thought i'd share the process with all
Its been 6 months since the last Zaino session on the car so it was about time for a strip down and top up.
Apart from a monthly or so wipe down with Z8 and maybe 1 or 2 layers of Z-CS the car hasnt had anything on it since having 2 layers or ZFX'd Z2 and a layer of Z-CS 6 months ago.
Couple of before pics, hadnt been washed for a week
DSCF1009 by n_d_fox, on Flickr
DSCF1010 by n_d_fox, on Flickr
DSCF1011 by n_d_fox, on Flickr
DSCF1013 by n_d_fox, on Flickr
So out with the Karcher and a rinse down. Still some beading going on
DSCF1014 by n_d_fox, on Flickr
Few welded on bugs around the front bumper, bonnet and front edge of the roof so out with a new (to me) product to try
DSCF1015 by n_d_fox, on Flickr
Sprayed all over the front end, bonnet and roof
DSCF1016 by n_d_fox, on Flickr
Then gave the wheels a good clean with Megs Wheel Brightener using various brushes and an MF mitt before covering the whole car with a Z7 and Starngloss red foam mix
DSCF1018 by n_d_fox, on Flickr
DSCF1019 by n_d_fox, on Flickr
DSCF1020 by n_d_fox, on Flickr
This was then rinsed before another new product for me to try
DSCF1037 by n_d_fox, on Flickr
Sprayed this all over the car and wheels and left to do its thing. Was quite surprised at the level of bleeding on the rear of the car, the bumper being covered in contamination
DSCF1021 by n_d_fox, on Flickr
Front wheels were pretty bad too
DSCF1022 by n_d_fox, on Flickr
Bit on the mirror caps
DSCF1023 by n_d_fox, on Flickr
Bonnet too
DSCF1024 by n_d_fox, on Flickr
Then just for completeness the rear wheels (actually not that bad)...
DSCF1025 by n_d_fox, on Flickr
Whole car was the foamed again with ValetPro PH Neutral and a good slug of Megs APC
DSCF1026 by n_d_fox, on Flickr
DSCF1027 by n_d_fox, on Flickr
Left this to dwell for about 5-10 minutes while i filled the buckets then rinsed. Was surprised to see what looked like a bit of sheeting going on
DSCF1028 by n_d_fox, on Flickr
Had a quick look round the car to make sure all the Decon Gel was washed away be washing the car (2BM) with Z7 and a DoDo SN sponge. This was then rinsed.
DSCF1030 by n_d_fox, on Flickr
DSCF1031 by n_d_fox, on Flickr
DSCF1032 by n_d_fox, on Flickr
While the car was still wet it was time for the final stage of decontamination, i've been a fan of DoDo SN clay for a while but after recently running out doing the A6 Avant i decided to try something new...
DSCF1034 by n_d_fox, on Flickr
Started with the bonnet using Megs Last Touch as lube. To be fair, not a lot coming off with the clay, this was after doing the whole bonnet
DSCF1035 by n_d_fox, on Flickr
This was after the drivers front wing and door which was the worst area
DSCF1036 by n_d_fox, on Flickr
Car was then given another wash with Z7 and a DoDo SN sponge before being rinsed and dried.
Before i went any further on the paint i wanted to seal the wheels and leave this to cure for a few hours.
DSCF1038 by n_d_fox, on Flickr
This was applied with a Megs foam applicator and then left to cure.
I also took the opportunity to give the exterior glass a good clean with Z12
DSCF1042 by n_d_fox, on Flickr
This was applied with a DoDo Blue Roo applicator and left to cure.
Time for the first part of the paint prep... I'd had a good look at the condition of the paint during the decontamination process and was happy that the protection over the last 6 months had been enough to prevent any real damage to the paint, there were a couple of small RDS but no swirling, holograming or marring so as i wanted to get the protection in place i decided not to chase the RDS' this time as they wouldnt affect the overall finish of the car.
First up then, Z-AIO via the DA with a Lake County Polishing pad.
DSCF1039 by n_d_fox, on Flickr
This was spread at speed 1 and then worked until clear at speed 4 before moving back down to speed 1 for a sweep over to finish. I worked my way around the whole car leaving the applied layer to cure before buffing.
At this point i buffed the glass and the wheels before adding the first layer of Z16
DSCF1043 by n_d_fox, on Flickr
DSCF1045 by n_d_fox, on Flickr
Front wing and door reflection after buffing the Z-AIO
DSCF1046 by n_d_fox, on Flickr
Time was getting on now, i wanted to get 3 layers of ZFX'd Z2 on the car so didnt take any pics during this process other than this one - New 2oz bottle and Zaino applicator
DSCF1041 by n_d_fox, on Flickr
Each layer was applied over the whole car and left to cure for around 10 minutes before being buffed. The car was then wiped down with Z6 before the next layer was added.
During the application of the 3rd layer it started to rain. The product had been on long enough to cure but the rain was getting heavy and i was having to dry each panel with a chunky MF before buffing it off. Fingers crossed that layer had chance to take properly !?
Few pics from before the rain came so around the 2nd layer after Z6 wipe down.
DSCF1048 by n_d_fox, on Flickr
DSCF1050 by n_d_fox, on Flickr
Added new Zaino sticker (thanks Johnny)  :thumb:
DSCF1053 by n_d_fox, on Flickr
The next morning i popped out to see how things has settled and found some quality beading
DSCF1055 by n_d_fox, on Flickr
DSCF1057 by n_d_fox, on Flickr
DSCF1058 by n_d_fox, on Flickr
DSCF1060 by n_d_fox, on Flickr
So that was it, a good days work and 3 fresh layers of Z2 applied. Thing was, i wanted to see what difference a couple of extra layers would make so a few days later i got started again.
Car was rinsed down with the hose and sprayer (no pressure washer needed), washed 2BM with Z7 and the SN sponge then dried before having a wipe down with Z6.
I then mixed up another 2oz bottle of ZFX'd Z2 and got another 3 layers on (with Z6 wipe downs in between). I also gave the wheels and door shuts a layer of Z-CS before applying another layer of Z16 to the tyres.
Few finished shots outside the back of the house
DSCF1063 by n_d_fox, on Flickr
DSCF1064 by n_d_fox, on Flickr
DSCF1065 by n_d_fox, on Flickr
DSCF1066 by n_d_fox, on Flickr
DSCF1067 by n_d_fox, on Flickr
Overall i am over the moon with the results, the first 3 layers of Z2 gave a lovely sharp finish and the flake in the paint really pops when the sun hits it. The additional 3 layers have added another edge though, given the finish a much glossier look and i'm glad i spent the extra time on Friday adding them.
I decided to take a few shots at a different location to see how the reflections came out.
DSCF1069 by n_d_fox, on Flickr
DSCF1071 by n_d_fox, on Flickr
DSCF1072 by n_d_fox, on Flickr
DSCF1074 by n_d_fox, on Flickr
DSCF1075 by n_d_fox, on Flickr
DSCF1076 by n_d_fox, on Flickr
DSCF1077 by n_d_fox, on Flickr
DSCF1078 by n_d_fox, on Flickr
DSCF1079 by n_d_fox, on Flickr
DSCF1080 by n_d_fox, on Flickr
DSCF1081 by n_d_fox, on Flickr
DSCF1082 by n_d_fox, on Flickr
Ok, so i got carried away with the after pics on the common but i was loving the colours on the trees and the way they were reflecting in the paint (although my photography skills dont show that very well !)...
Only thing left to do now is a couple of layers of Z8 after the next 2 washes :D
Thanks for taking the time to look through these... comments welcome ;)
Nige  :thumb:
Parting the rush hour traffic like a diesel powered Moses !
OCD.etail - http://www.facebook.com/pages/OCDetail/174298162661463
Offline Daffy
Re: Zaino Winter Prep / 6 month application - Leon FR
« Reply #1 on: December 01, 2011, 06:55:43 pm »
Cracking results there the second dose of Zaino has really added some sharpness to the finish. Z8 is my favourite product  leaves a great finish and smells fantastic, also dead easy to use. All the Zaino range of products are great and I rarely use anything else these days its just not necessary.
Offline n_d_fox
« Reply #2 on: December 05, 2011, 04:32:11 pm »
Thanks for the comments matey... i know what you mean though, really are superb products... i keep thinking about waxes etc  :rolleye: but then remember how much i love the finish on my car from just the Zaino products i have  :happy2:
