Author Topic: Can I change how heavy my steering is?  (Read 7925 times)
Offline AjayB
  • Golf GT TDI
« on: November 29, 2011, 12:10:13 am »
Is changing the heaviness of my power steering possible on my 2004 gt tdi through VCDS?. The steering feels too light at the moment.
« Last Edit: November 29, 2011, 12:15:12 am by AjayB »
Build: http://www.mk5golfgti.co.uk/forum/index.php/topic,40699.0.html
Golf MK5 GT TDI | 35mm H&R Springs | Silver Cabon Fibre Inlays | 20% Rear Tints | Backbox Delete- Dual Tips | GTI Rear Valance
To Do: RNS/RCD510 | FBSW | Black BBS CH 18"
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Can I change how heavy my steering is?
« Reply #1 on: November 29, 2011, 12:49:48 am »
hmm i'm interested in this too. my steering has become lighter since i swapped to lighter wheels. it'll get lighter still when i get my NQS and lighter discs on. if it could be beefed up a bit that would be good!
PLANS: Stage 2+
Offline Little_Dave
« Reply #2 on: November 29, 2011, 12:58:51 am »
Somebody mentioned on here about when you add WALK is makes the steering a little bit heavier and you'd have the added bonus of less understeer etc  :happy2:
Dave
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #3 on: November 29, 2011, 01:08:06 am »
That's good to know. Got a WALK waiting to go on!
PLANS: Stage 2+
Offline Little_Dave
« Reply #4 on: November 29, 2011, 01:10:29 am »
Got one on the way with an autotech rear ARB  :party:
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #5 on: November 29, 2011, 01:14:55 am »
Lmao me too :happy2:
PLANS: Stage 2+
Offline AjayB
  • Golf GT TDI
« Reply #6 on: November 29, 2011, 01:38:47 am »
Whats WALK guys?
Offline Little_Dave
« Reply #7 on: November 29, 2011, 01:39:41 am »
Whiteline anti lift kit  :happy2:
Offline Beddie
  • -Receive: 76
« Reply #8 on: November 29, 2011, 07:14:42 am »
Steering 'weight' can be adjusted with vcds, I did it on my 2006 A3 as I really disliked the light steering after coming from a mkv gti, you need to adjust the value in the 'steering boost' setting
The lower the value the heavier the steering will feel due to less electrical assistance and it does make quite a difference to how the car feels imo  :happy2:
I believe the ability to change this setting was dropped on 2007-on models but you should be able to change it on a 2004  :smiley:
For info my A3 S-line was set at '6' from the factory compared to a friends mkv gti which at the time was set to '3'..
Carbon Grey Edition 35 - Here
Offline Felix
« Reply #9 on: November 29, 2011, 10:03:44 am »
As above, my steering is firmer after the install of the superpro wishbone bushes with anti lift and mount  :happy2:
300hp Mk5 Golf GTi Edition 30
Offline mkviken
« Reply #10 on: November 29, 2011, 11:32:05 am »
i fitted the WALK to my mk6 gti and the steering is definitely a little heavier which i prefer. i would like it heavier still but don't think its adjustable on the mk6
Offline dan_the_v8man
« Reply #11 on: November 29, 2011, 03:36:02 pm »
Beddie is correct, the later cars this isnt possible on
Offline Beddie
  • -Receive: 76
« Reply #12 on: November 29, 2011, 05:21:29 pm »
Here's a quick how to on changing the steering boost settings  :happy2:
Click on '44-Steering assist'
When you go into this module, it will scan for fault codes and go straight to a fault code screen. It should say 'No Fault Codes Found'. Click the 'Done, go back' button to get to the main screen for this module.
Click on 'Adaptation - 10'
Click on the 'Channel Number' "Up" Icon until it shows Channel 1
Click the 'Up' or 'Dn' buttons to get to a new value, don't just type it in. People report liking '0' (least boost) through '3' as new settings, I personally prefer '2'.
Click 'Save'
It may ask "Are you sure", click "Yes"
You may want to check again to make sure your new setting is showing up in the 'Stored Value' field, just to be sure.
Click 'Done, go back'
Click 'Close controller, Go Back'
