Author Topic: 1 small clunk/knock when pulling away? A common lowered A3/MK5 Golf issue?  (Read 2025 times)
Offline TimG
Firstly Hi, browse on here a bit, but never get round to posting much being on ASN most of the time!
I have had this issue before on my 2003 Polo, after installing coilovers and then doing a few thousand miles and now my A3 has developed it. As I'm pulling away from stationary (just as the clutch bites and the wheels start to pull the car along) I get a pop/ click noise which sounds like its coming from underneath the car somewhere, possibly footwell area or underneath the forward seating area. It is one click/clunk and thats it, until I stop and pull away again. It never happens at speed, just the initial load of pulling away and sometimes braking to a halt.
I've checked all the wheel nuts and they're fine, so its not that (although it kind sounds like it did when I had some loose ones of my previous car!).
I'm wondering if it is the chassis/subframe bolts not being tight enough and allowing some very slight movement when the chassis is placed under strain when pulling away... maybe?
Anyone else experienced this at all? I have heard the MK5 Golf lads complain of similar issue on lowered cars! Its definitely chassis/subframe suspension related I'm sure of that.
Offline alackofspeed
  • -Receive: 24
Re: 1 small clunk/knock when pulling away? A common lowered A3/MK5 Golf issue?
« Reply #1 on: November 29, 2011, 08:00:42 pm »
This maybe?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2 on: November 29, 2011, 08:22:55 pm »
Mine does this aswell, only when pulling away or driving slowly over a tiny bump :scared: vw couldn't diagnose anything, they said it was probably bottoming out  :grin:
I'm lowered on H&R springs
Offline TimG
« Reply #3 on: November 29, 2011, 08:24:34 pm »
This maybe?
I found a link to this on E38 a minute ago actually and the noise in the video is similar to what I get, so it might well be this. Gonna try and check my subframe bolts tomorrow see if they are loose at all!
Not sure why fitting coilovers/lowering would suddenly cause this issue though, unless the added stiffness to the chassis has an affect somehow.
